D14 oil just poured out :( |
Post Reply ![]() |
Justified ![]() Bronze Level ![]() Joined: 11 Aug 2018 Location: Missouri Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Aug 2018 at 3:06pm |
Hey guys, I've owned a AC D14 for about 6 months now. It is the first tractor I have ever had. It has been great and I use it just about every week. I noticed today it started sounding rough. I noticed the oil had very low pressure. I put 3-4qts in the top block and 30 minutes later it is rough again and no pressure. I look underneath...no drain plug! I guess it fell off at some point. At least that small hole looks like it would be the oil drain plug right? Second question. That metal circle hanging there goes flush up against the bottom when I push it in but it doesn't feel like it would be flush to hold any fluid back. Is that large cirlce have oil on the other side that it is keeping in too? What is that large circle piece called? I can't find where I can buy one. Thoughts guys? Appreciate your help. :)
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24571 |
um hate to be the bearer of bad news but the engine oil drain plug is on the oil pan, bottom of the engine. if all the oil's coming out the 'big hole', you probably have a very leaky 'rear main seal' the big hole is at the bottom of the clutch housing and it should be dry. I'm sure others with more knowledge will chime in, looks like you'll be splitting the tractor to fix though. Jay
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
As for your oil pressure gauge. If you ran the engine out of oil the gauge should be reading no oil pressure, not low oil pressure. If it started running rough you already have engine damage. Generally the first thing you'll see is a rise in engine temperature, eventually followed by engine seizing.
Edited by DougS - 11 Aug 2018 at 3:25pm |
yeah, I was just going to come back and say this very thing that it isn't the oil drain plug. So what I'm hearing is I have to take this thing apart to fix this?
If it's losing oil that fast you have a major seal leak. It couldn't leak worse if there were no seal installed at all. While it's apart you might want to check the rings and bearings. Hopefully you didn't damage the crankshaft.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53837 |
At the very least, by the looks of that clutch inspection hole cover, you need to split tractor, and clean up clutch, and instal rear oil seal, and pan gasket. If you have it apart, and the oil pan off, might as well check all the bearings. This means major teardown...
squirt239 ![]() Bronze Level ![]() Joined: 12 May 2017 Location: Brownsburg, IN Points: 69 |
Might be a major teardown, but I've done mine twice in a years time. It's not as bad as I thought it would be. I did a little bit at a time. When I got frustrated, I had a whiskey and a cigar until the frustration subsided. Sometimes it did, sometimes it didn't. Life's about the journey, not the destination. Enjoy the suck :-)
Acdiesel ![]() Orange Level ![]() ![]() Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2574 |
oil pump is also located at the top right of the flywheel it could be leaking as well.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87090 |
that's what I was thinking... pump gasket failed, or the tube screwed into it broke........ but if the engine is rough, your still going to have to pull the pan and look at bearings.
Post Reply ![]() |
