190XT Gas
190XTLP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTLP Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Gas
    Posted: 30 Jul 2018 at 12:44pm
Engine runs perfect except for a bad governor hunt at mid speed
Has been adjusted per service book...bad spring?
Any ideas?
WD45G,WD45D.190XTD,190XTLP
D19LP,WC unstyled,WF unstyled
WC styled,220
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2018 at 1:12pm
I have never seen a 190's governor setup but on the 45 and D14 I have, the linkage was the problem.  Especially across the front of the engine.  I sprayed the linkage system with PB Blaster a couple times, then lubed with a silicon spray lube.  Hope that helps, good luck.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2018 at 7:16pm
Make sure the throttle shaft ear where the linkage hooks up on the carb has not come loose. I have had that happen twice and will make the governor hunt as you describe.
