D 14 Carb Issues
Rod5300 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod5300 Quote  Post ReplyReply Direct Link To This Post Topic: D 14 Carb Issues
    Posted: 29 Jul 2018 at 5:54pm
I took the carb off my D 14 and cleaned it out, Put it back together and it runs pretty good but seems like it still stopped up,, Once in awhile it will act like its straving for fuel and then take off and smooth out. Any ideas of something I missed and also can the venturri in the carb be placed backward or does it make a difference.
I sprayed a couple of pasture fields with it.. I enjoy using the little tractor
Thanks Forum Friends for your help
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2018 at 7:52am
I don't think it would run with the venturi  upside down. Could be a restricted fuel line or a governor issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2018 at 8:38am
check the gas tank !! could be 'something' semi floating in there and gets to plugging the gas .....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod5300 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2018 at 6:50pm
Thanks for your reply as to my carb.. Ive checked the gas tank and found nothing stopping the flow of gas, I was wanting to put in a inline filter would that hurt with gas flow. Maybe I need to take it off and clean it again.. I spray pastures with it,   again thnks Rodd
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2018 at 7:05pm
When it acts like it needs fuel or is missing, reach down and choke it a little and see it it smooths out or not. That should confirm if you have a real gas issue.  My D14  does it too and I know I have to clean out the tank this fall. Usually it smooths out from bumping along and reminds me to put it on the to do list.   If choking it makes it worse you might not have a fuel issue.  Good luck.  I love both of my D-14's.
This page was generated in 0.176 seconds.
