Hydraulic cylinder stop collar
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic cylinder stop collar
    Posted: 23 Jul 2018 at 11:54am
I have bush hog on my WD 3 point. It tend to go all the way down as I mow.
My questions:
Has anyone put stop collars on the cylinders to set the low position?
If so how do they hold?
What size is the cylinder shaft?
Where did you get them?
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 12:37pm
I've never used them on a 3 point, but have used them on a remote cylinder.  Work great.  I bought two packs of them and mistakenly 1 was a bigger size, but the bigger size ones are fine too. I bought mine from a Deere dealership, but I'm sure they're available numerous places.
Edited by Tbone95 - 23 Jul 2018 at 12:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 12:49pm
I doubt cyl stops are gonna work very well on lift cyl's on a WD because of the geometry at the end which pins to the lift arm lever. Nothing good to seat against.....
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 12:50pm
Farm Supply stores...TSC, Orscheln, etc.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 1:05pm
X 2. I'd read what Steve posted above, it will save the rockshaft arms from damage.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 3:40pm
Actually, for me they work well.  They were on my WD 45 3pt with a Woods brush hog when I got it.  That's been over 10 yrs. ago.  I was concerned that they would batter up the cylinder nut on the end of the ram but they don't seem to hurt it.  I've re-packed the cylinders and had both of them apart with no damage done by the collars.  You can vary the cutting height by the number of collars you use as well as the 3 pt adjustment.  They are pretty much universal as far as diameter is concerned and are 2 halves with a spring clip wrapped around them.  Again, for me they work well--opinions may vary.  Available at most farm supply stores.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 3:50pm
If I was going to use the depth collars, I'd sure use them on BOTH cylinders to make the load 50/50% between them.  I remember a depth stop rod that was used on the mounted cultivator with the rear scratcher. That was easily adjusted with a wrench and placed no stress on the lift cylinders whatsoever.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2018 at 7:47am
Thank for the comments.
So if you have used them, did you have floating collars or locking collars?
And yes the plan is defiantly to put them on both cylinders if I decide to do it.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2018 at 7:59am
I've used a number of floating collars on both lift cylinders to limit the depth while using a SC subsoiler.  I've found it works well.
Steve's concern is correct if you're trying to use enough stops to have the lift arms fully raised.  I've tried that also for transporting a SC plow with tailwheel.  It works, but I wouldn't want to use it for an extended period that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2018 at 9:06am
I use them floating on the cylinder and not to hold cylinders anywhere close to there extended length. If cutting at different heights it may be necessary to remove one from each side being careful that both sides are equal and it beats trying to do it with the pump.  It's not the handiest place to get at but usually you don't change them that often.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 9:57pm
use them on both cylinders on my 45 diesel with a bush hog.relieves the hyd pump from holding it in the 110 degree texas temps.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 6:26pm
Someone makes a chain arrangement that limits how far the 3pt arms can go down.  Works well on my WD
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 8:47am
Woods mowers had a chain limit system on them before they went to 4 casters.  Isn't there and adjustment on the hyd pump for setting this stop up?  If I remember correctly, you lower all the way and then go back up on the lever to a center detent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2018 at 2:19pm
Maybe a guy should get into reproducing the depth stops for these old things.
http://allischalmers.com/forum/uploads/298/051.JPG
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 9:21am
Neat Charlie, I never saw that before.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 9:31am
Think I'd go with the collars on the shaft,a WD is hard enough to get on and off or already
This page was generated in 0.254 seconds.
