Allis 180 gas - engine doesn't want to shut off...
allispicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Topic: Allis 180 gas - engine doesn't want to shut off...
    Posted: 17 Jul 2018 at 9:36am
My 180 gas tractor start and runs well, but the issue I'm having is that when I turn the key off, the engine acts like it wants to stop but will stay running at 100-200 rpms and I have to put it in gear and hold the brake to kill the engine.  Any ideas?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 9:51am
must be carbon in the engine... Cleaned your spark plugs? Maybe try setting low idle screw lower? Probably carbon on the exhaust valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 10:42am
Your engine is "dieseling" ??????????      Low idle must be at 400 RPM and you have to idle it that slow for maybe a minute before shutting the key off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 10:55am
What is "dieseling" and how do I fix the issue?  I have never had this problem with any of my other gas tractors.  I'll try some new plugs as well.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 11:18am
dieselling is when a gas engine has so much carbon buildup in the cylinders that you don't need a spark to ignite the gas/air mixture. Usually running the choke too much, over time allows the buildup to occour.
Best solution is to pull the head and scrape the buildup off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 11:33am
Thanks for the information, I'll work on pulling the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 12:05pm
Jump right in and do the worst possible scenario !!   Let's pull the head before going to AC Delco 44XL spark plugs or making SURE the low idle is at 400 RPM and before we allow it to idle slow for 60 seconds before shutting off the switch and before it has maybe a better grade of gasoline  ?? Yup. That's what I would definitely NOT DO is yank the head.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 12:10pm
Yeah, usually its a piece of carbon that gets so heated up and retains that heat so that it continues to ignite the gas after the spark is shut off.
Pulling the head is the best way, certainly, but you could try any number of way to try to reduce the carbon, including something like Seafoam or even water....very carefully.
[TUBE]KFtp_jmLF3k[/TUBE]
Edited by HoughMade - 17 Jul 2018 at 12:11pm
1951 B
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 12:11pm
I agree with the dr.  if those don't work then put on a dyno and apply load slowly over time to burn that stuff off.  don't just go to full load right away as it will detonate.  another option is to mist water from a squirt bottle in the carb when running.  this will cool the carbon and it will likely flake off however it could stick a chunk in a valve seat and lead to a burnt valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 1:02pm
@Dr. Allis - great perspective!  I'll try the quick/easy/cheap fixes first Thumbs Up
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 1:58pm
An excellent product is to remove internal engine carbon deposits is KREEN from KANO Laboratories in Nashville, Tn.
I use BG products and SeaFoam but like the results from KREEN the best.
KANO Labs is the maker of KROIL.
Edited by Clay - 17 Jul 2018 at 2:12pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 2:20pm
The last thing I'd do is pull the head.
BTW I gotta say the good dr has a way making his point. Thumbs Up
Wink
I am a Russian Bot
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 3:20pm
First pull and clean the plugs. After that a Seafoam treatment. Run at fast idle mist it with Seafoam till it quits. Let it sit a hour star it and run it hard. I had a C that was very bad I added one gallon diesel in five gallons gas and mowed the yard. It ran hot the fist time I've ever seen the temp guage actually make it to operating temp and spit out lots of carbon bit from the exhaust burned a few holes in my mowing shorts. After that it ran like a dream.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 9:28pm
I would also check timing. Advanced timing can cause hi cylinder temp and burn pistons.    MACk
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 4:59am
In days gone by disreputable gas stations would set the idle a bit high and mess with the timing to make cars diesel like that. Their answer to the problem was high test gas. Do a proper tune up by the book specifications and let it cool a bit at idle before turning the key off, and I’ll bet your problem goes away.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 5:23am
Back in the early days of smog control dieseling was a common problem. They even installed anti-dieseling solenoids on some cars. I believe timing was the cause. Some cars were timed to fire AFTER TDC. Firing at 0 degrees was common.
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 12:42pm
Unwire the alternator and see if it still runs on
