Fuel Pumps and Off-Season Storage
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Pumps and Off-Season Storage
    Posted: 23 Jun 2018 at 6:00pm
I have read on "here" and other forums about fuel pumps(diesel) getting gummed-up while sitting for extended periods. Out XT sits from late Nov.-late march without running and "knock-on-wood" have not had an issue. Just wondering if simply moving the throttle lever/shut-off lever would keep internals loose? Not sure if anything could be  done to the 433T in the combine though other than moving the throttle lever. This is strictly without starting the engines. Thanks
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 7:52pm
I am in NC so our winters aren't as harsh as yours but I am very proactive with our fuel supply tank on the farm and try to keep the freshest fuel and I will add additives to the tank but before I park everything I fill them up and add more additive to the tractors fuel tanks. Aside from running the tractors at least once a month I am not sure what moving the linkages would do but I would juice the fuel up and run the tractors before parking them for the winter.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 9:40pm
What you are referring to may be Bio diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 9:45pm
Don't use bio diesel and they can set as long as you want. I pay extra for straight diesel cause it's worth it!
This page was generated in 0.250 seconds.
