Need quiet muffler for wd45 tractor |
Post Reply ![]() |
case310350 ![]() Bronze Level ![]() Joined: 26 Apr 2013 Location: United States Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jun 2018 at 8:38pm |
Looking for a muffler that will be much quieter that the original. I see nelson is popular but is it quieter? also need air cleaner to carb hose.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3941 |
quieter than what ?
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
If you still have the old hose, take it to a good auto parts store. A non chain type store is better. If you're nice they will find a hose that has a piece shaped like you need that you can cut out of it.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3073 |
Steiners has the carb to air cleaner hose. Site sponsors on here probably do as well
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
The old Nelson is maybe slightly quieter than a cheap stanley but if you are looking for real quiet then an oval muffler is much better and there again a nelson is quieter than a cheap stanley. An oval, of course won't fit your hood unless you cut it out or you extend the pipe above the hood.
Wink I am a Russian Bot |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8663 |
I cut the oval in the hood and installed D17 oval muffler (requires pipe manifold) and that was great till the vibration broke out bottom. Back to a Nelson with ear plugs. Not the main tractor anymore so not much drive time.
polarbear ![]() Silver Level ![]() Joined: 05 Jul 2016 Location: addieville il Points: 331 |
go to Agco and get one same price as Steiner or DJS
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22091 |
Have a muffler shop built you a pipe that comes up thru the hoods hole and bends forward horizontally towards the radiator. Connect a D-17 series 4 muffler to that and lay it horizontally directing the noise out in front of you. Support the muffler with a bracket of some sort to the hood or side frame. It will be quiet in the seat.
Post Reply ![]() |
