Hydraulic questions 8010
Chad80 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad80 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic questions 8010
    Posted: 12 May 2018 at 1:11pm
I have a question about hydraulics, My tractor is an 8010 and I was using it the other day Mowing with a 15' battling mower. It would let me raise the bath wings but it would not let me control my height level. I disconnected in hotep to other implements having the same issues sometimes I cannot get my remote to work at all. I have 3 remotes on this tractor and all of them are doing the same thing. Any suggestions?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 1:25pm
If it was just one lever...I'd say adjust the cable.
If it is all three levers...check hyd filter, oil level, hoses, then pump pressure. standby pressure, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 10:18pm
Could be bad couplers. If it has levers on couplers, that would be a good place to start.       MACK
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 7:14am
I have had problems with a fertilizer buggy doing that one time. One coupler had pressure and wouldn’t release the tip even though it was plugged in. It is a pain. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad80 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 7:45pm
Mack, where can i buy replacement coullers? I have do have the style coupler you mentioned.
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:30pm
If it has the lever lock style couplers throw them in the can, call salvage yard and get the earlier style couplers get the adapter nipple to plumb and never have to worry about them again.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:49pm
Your Agco dealer should have then or most farm supply store.   MACK
Transaxial View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Transaxial Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 8:38am
Since you call this problem "sometimes" it might be a coupler problem but that usually does not happen to all of them at one time. Just something to think about is a little spring in the hydraulic pump (3/8" dia x 1/2" long and some shims) that sets the standby pressure of the pressure comp circuit. It is accessible through a plug on the outside of the pump and I have had it break which just stops all hydraulic function. If yours is broken such that you have reduced pressure , you could have intermittent hydraulic function??? Just a far out guess!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 11:54pm
Tornado do you have a picture of your couplers after you changed it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 1:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 11:12pm
I ask because I'm looking at a 8050 and it has lever type and it has wire tie around them, and couplers look different then others IV seen with lever type
