WD45 hydraulic pressure |
sadmyentist
Topic: WD45 hydraulic pressurePosted: 04 May 2018 at 6:07pm |
So I'm trying to assess the health of my hydraulic pump. When I disconnect one cylinder and hook up a gauge, the gauge hits a 3000-3200 psi transient when the rockshaft hits its stop, then drops to 2500 psi....I'm guessing that is where the unloading valve is currently set. Then it slowly drifts down to 1500 where it stabilizes. I'm thinking that might be the dripping from the gauge threads.
Any thoughts on this state of affairs? Thanks all, Rob
DrAllis
Posted: 04 May 2018 at 6:58pm |
Sounds like a system that would be working and functioning just fine and would never have had a gauge connected to it because of that. 3400 psi is max setting. Anything over 3,000 I consider very normal. They don't build 3000 or 3400psi and maintain that pressure.
sadmyentist
Posted: 04 May 2018 at 7:04pm |
10-4. Much appreciated!
