2500 Disk problems!
j birke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j birke Quote  Post ReplyReply Direct Link To This Post Topic: 2500 Disk problems!
    Posted: 20 Apr 2018 at 6:48pm
The bearings in the spindle hub shot turds and destroyed the spindle. The unit is a early serial number! Is it a solid axle and what's the best way to replace it? AGCO parts book shows stub shafts in it on later models?
25-40, WD-45, D14, D17D, D19G, D19G, D19D, D19D, 185, 190G, 190D, 200, 7000, 7060, and 8030
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 11:09pm
Sounds like a trip to a machine shop. Get a new one made, and weld it in.
The hub you can get anywhere.
Get one with a grease nipple or put one in.   Then grease your other one(s) too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 11:16pm
I got a new spindle with hub from local farm store and welded it in on my plows
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 8:03am
A new spindle isn't the bad part, getting the old one out usually is.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 10:52am
What we have done with welded in spindles that have to be replaced is, after the spindle is removed, weld in a piece of schedule 80 pipe, the spindle slides into the pipe, then run a bolt through the pipe and the spindle. Makes replacement the next time a lot easier.
This page was generated in 0.057 seconds.
