Help with D-series lights?
JWV Fulton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWV Fulton Quote  Post ReplyReply Direct Link To This Post Topic: Help with D-series lights?
    Posted: 08 Apr 2018 at 7:24am
Does any one make or sell the bolts to mount the D-series fender headlights? I need 2 bolts to replace some rusty stripped out old ones. Thanks!
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 7:03pm
I'm with you on needing these. So chiming in to follow the post
D17 Series 1
Allis B- 1939
Allis B- 1945
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 8:16pm
I'll post a picture in a few days.  I've managed to salvage a few.  I think the bolt itself can still be found without the hole through it, so that is a good start.  Check with local industrial suppliers.  If they carry them, you would just have to drill a hole through them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 8:51am
I needed a couple headlight bolts once. I got the lowest grade bolt at the hardware store and drilled right down the center with a drill press.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 10:47am
A 1/2" plow bolt with a hole drilled down the center.
or a carriage bolt will work great too.
I've used both.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
This page was generated in 0.189 seconds.
