Salvage for Sale
outbackfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote outbackfarm Quote  Post ReplyReply Direct Link To This Post Topic: Salvage for Sale
    Posted: 24 Mar 2018 at 2:51pm
I have a 4wd 6140 with an engine problem I cannot fix. Looking to sell for salvage.
Please contact me if interested jeff@outbackfarm.net
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2018 at 3:41pm
If you were closer id be highly intrested. That looks too good to salvage, and a matching loader with fwa. Hope someone could get it going
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2018 at 4:34pm
Does that use the 3 cylinder Perkins like the 160?
Edit:
Just looked it up and it uses a Toyosha  diesel
Edited by WF owner - 24 Mar 2018 at 4:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2018 at 4:39pm
Production:
Manufacturer:Allis Chalmers
Original price (USD):$15,891
Allis Chalmers 6140 Engine:
   Toyosha 2.3L 3-cyl diesel
full engine details ...
Capacity:
Fuel:13.2 gal [50.0 L]
3-Point Hitch:
Rear Type:I
Control:top-link draft sensing
Rear lift:3190 lbs [1446 kg]
Power Take-off (PTO):
Rear PTO:independent
Rear RPM:540
Dimensions & Tires:
Wheelbase:76.2 inches [193 cm]
Weight:4000 to 4400 pounds
Front tire:6.00-16
Rear tire:13.6-28
full dimensions and tires ...
6140 Serial Numbers:
Location:Serial number on the left side of the fuel tank.
1982: 1001
1983: 1726
1984: 1851
1985: 2711
how to read serial numbers...
Allis Chalmers 6140 Power:
PTO (claimed):40 hp [29.8 kW]
Mechanical:
Chassis:4x2 2WD
 4x4 MFWD 4WD
Final drives:inboard planetary
Differential lock:mechanical rear
Steering:power
Brakes:mechanical wet disc
Cab:Open operator station. ROPS and canopy available.
Hydraulics:
Type:open center
Pump flow:10 gpm [37.9 lpm]
Electrical:
Ground:negative
Battery:
Number:1
Volts:12
Page information:
Last update:February 26, 2018
Copyright:Copyright 2018 TractorData LLC
Contact:Peter@TractorData.com
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 10:58am
DON'T SCRAP IT!!!!!! Cry  If I was closer, I'd snap it up in a second!!!
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote outbackfarm Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 3:12pm
I don't want to scrap it.  I used it regularly until last weekend when the engine noise started.  I just can't find the engine parts to fix it.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 4:12pm
I would think with the internet connected to the whole planet there must be parts out there somewhere to fix your engine, or someone knows how to swap in a Kubota or other engine. Don't give up so soon as that is a great size tractor.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 10:19am
What parts do you need? Rings, bearings, gaskets and seals are easy.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 3:39pm
how about a perkins ad 3 or ad4 swap to bad eveything is across the country from me
Post Options Post Options   Thanks (0) Thanks(0)   Quote outbackfarm Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 8:02pm
would that fit a 6140?
Post Options Post Options   Thanks (0) Thanks(0)   Quote outbackfarm Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 8:06pm
I'm not exactly sure what parts I will need.  It was running fine until last weekend.  Then it stalled and now has a squeal in the engine then I crank it. It seems cam related .  Engine seems to bind when one valve is in the down position.  When I removed the rocker arm assembly it seemed to free up.  So that's why I'm thinking cam bearing but I could be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 6:12am
The camshaft would still turn with the rocker arms removed, so I doubt it's cam bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 7:09am
Do you have a way to manually cycle the valves to see if one may be bent for some reason?
Timberjack@48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timberjack@48 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 4:41am
Did you end up selling it?
Drok664 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Drok664 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 9:35pm
What end up happening to your tractor
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2019 at 4:45pm
Hope he answers you, but he hasn't signed in since April 2018.
This page was generated in 0.297 seconds.
