Inching Pedal installed on D17 , Who has seen one |
Post Reply ![]() |
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Mar 2018 at 9:48pm |
Anyone have photos of an inching pedal installed on a D17 ?
Share please . Thanks in advance !!!! Edited by Macon Rounds - 19 Mar 2018 at 11:20pm |
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
I was of the understanding that inching pedals were used with hydraulic clutches, how would an inching pedal work on a traditional clutch?
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2262 |
Foot pedal on the PD clutch?.....just a wild guess!
Inching pedal attaches to left side of PD shaft and is strictly mechanical function using your left foot.
Not sure if this was ever a factory accessory or just creative farmer invention. |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3047 |
Seems Like Doc theoreticcaly explain how to build one on here a few weeks ago
Here is were it would be installed.
![]() ![]() Edited by Macon Rounds - 20 Mar 2018 at 7:12pm |
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
PleASE explain. Been around AC 63 years. Never heard of it. Always nice to learn something new!
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1278 |
I have seen a pedal on the left to run the F-R shuttle.
Travis2766 ![]() Silver Level ![]() ![]() Joined: 26 Aug 2015 Location: Amherst, Wi Points: 434 |
I’ve always wondered what that stub shaft was for.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
Ken(MI) ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
A true inching pedal is incorporated into a torque converter drive and releases the brakes and engages the clutch in a timed motion which, if everything is adjusted correctly, will prevent rolling in the opposite direction of desired travel, anyone with forklift experience knows exactly how this works and what a benefit it is, especially in rigging and spotting operations. A pedal on the PD shaft would only allow foot control of the clutch and not combine the releasing of the brakes, might be handy, but I'm not sure what for.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
I have a I600 fork lift with what I would call a inching pedal. You would not want it on a tractor or a fork lift.
It is a valve about like drag link steering, with a small cylinder hooked to PD LINKAGE WITH FOOT pedal going to valve. I don't like it. MACK |
Yea Mack, This hydraulic activated one was on my I600/D15. "Yea someone painted the tractor green" This type completely engages
![]() The inching pedal I am referring to only lets you slip the power director clutch when in situations you need to just inch the tractor, it will not fully engage the PD.
Edited by Macon Rounds - 20 Mar 2018 at 10:15pm |
It would really be handy for inching backwards to hook up equipment. As its hard to reach the power director handle and see the hitch at the same time. In addition my helpers "Wife and kids" are not as smooth with the foot clutch as one would like. Safe just not smooth. And having a smooth inching capability would make for a much more harmonious day around the farm. ![]() Edited by Macon Rounds - 21 Mar 2018 at 9:53am |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21893 |
The extra length of the P.D. shaft was for a left-hand control lever. Usually this was a Fwd-Rev "shuttle-shift". The foot pedal design was hydraulic and totally eliminated the left side hand lever. I suppose you could rig up some sort of manual "inching" pedal, but you'd have to eliminate the neutral latch in order for it to work as you hoped for.
Dr Allis you explained it exactly as i understand it. However no need to eliminate the neutral latch. Just posion the leaver up out of the notch and a little foward when you need to use the inching feature.
I guess i am just gonna have to engineer one if i cant find a prototype to design off of. |
Post Reply ![]() |
