Allis WC head gasket change tips and tricks |
Post Reply ![]() |
Page 12> |
AllisWCLaRock ![]() Bronze Level ![]() ![]() Joined: 19 Mar 2018 Location: Newyork Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Mar 2018 at 10:13am |
I'm going to be changing my head gasket on my 47 wc and was looking for some tips and tricks like how to torque head what pattern what to use for cleaning etc... Any help is appreciated thanks ahead of time!
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Should be covered in the WC shop manual pieces I have on line at:
http://geraldj.networkiowa.com/Trees/wc%20service%20pt%201.pdf http://geraldj.networkiowa.com/Trees/wc%20service%20pt%202.pdf http://geraldj.networkiowa.com/Trees/wc%20service%20pt%203.pdf http://geraldj.networkiowa.com/Trees/wc%20service%20pt%204.pdf http://geraldj.networkiowa.com/Trees/wc%20service%20pt%205.pdf http://geraldj.networkiowa.com/Trees/wc%20service%20pt%206.pdf http://geraldj.networkiowa.com/Trees/wc%20service%20pt%207.pdf http://geraldj.networkiowa.com/Trees/wc%20service%20pt%208.pdf http://geraldj.networkiowa.com/Trees/wc%20service%20pt%209.pdf Each section is large just under 10 MB. Gerald J. |
Do you have the regular manual that would have tourque specs?
LeonR2013 ![]() Orange Level ![]() ![]() Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Clean. Clean. And then clean again.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3042 |
Be really careful not to drop junk down in the cylinder when cleaning. You'll never get it back out...
He's a topic a wrote last year when I rebuilt my WD45 last year. There a couple sections about head rebuilds and install. Sorry the pictures got screwed up by photobucket. |
http://www.allischalmers.com/forum/201-engine-assembly_topic118485.htmlHere's another good one by littlemarv
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21838 |
Clean all block bolt holes with a thread tap and compressed air. Use light grease or oil on head bolt threads. If you don't paint the head gasket with something, it will probably seep water and oil. I prefer to use a Hylomar type sealer applied with my finger around all water holes, push rod holes, and all the way around the outer edge of the gasket on BOTH sides. Retorque after some running time when stone cold. All tappets at .015" when cold.
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
![]() ![]() You can buy it in small tubes , |
Interesting, I've never seen that before. Would it be similar to #2 permatex non hardening sealer?
Dave , Not even close
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
This might help too.
So should I put that around all the holes head and block or on both sides of the head gasket?
Either way works. Just make sure you spread it thin with no globs.
Dose any one have a diagram of how to tourque the studs and specs
There should be a diagram and torque specifications in one of the WC shop manual sections I posted above. I haven't memorized them to know which section covers engine assembly.
Gerald J. |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5012 |
The Hylomar Universal Blue is available through Amazon. I tried to post the link, but couldn't get the link to work.
Edited by WF owner - 22 Mar 2018 at 10:09pm |
GreenMule ![]() Bronze Level ![]() ![]() Joined: 09 Dec 2017 Location: NC Points: 26 |
you can get it on e-bay also, going to try it
Best to buy it on e-bay ,I get mine from a local Speed Shop
It doesn't show how to reinstall the head in there dose any one know ??
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Be aware that using any kind of sealer on some head gaskets, Fel-Pro comes to mind,voids the warrantee.
http://www.allischalmers.com/forum/wd45-rebuild-progress_topic126761_page2.html
Here's my thread on my WD45 head installation. Pretty similar. Torque the 1/2 bolts and studs to 90ft lb. The 3/8 studs get 25lbs per the Allis service manual. From Memory only, tighten the 1/2 bolts and studs starting in the center and working out. The 3/8's studs get tightened last. Center stud first then the 2 outers. For more detailed info about re-torqueing or may being torqueing in steps, read the above thread. If you have more questions let us know.
That shop manual sure skips cylinder head installation. As does the op and maintenance manual available at:
http://grandpas-tractor-site.s3.amazonaws.com/manuals/ac/WC-WF-RC/wc-operators-manual-complete.pdf?javer=1803231002 So I guess Dave's extraction from WD manual can be applied. Gerald J. |
So I did the head gasket put it all together and it runs on 3 cylinders I checked spark it has super strong spark spark plugs is good I'm lost on what to do any suggestions
You start by making sure the plug wires are on correctly. Firing order is 1-2-4-3. Then, you run a simple compression test to verify good and equal compression pressures. Do this with the throttle WIDE OPEN and a battery charger on the battery. Make each cylinder hit at least 6 times or more.
I'm pretty positive it's compression but what would cause it to have little compression with a new head gasket?
Do you have a valve that is stuck open?
No
Maybe I should have said, do you have a valve that is not closing completely?
A valve that hasn't been ground to the seat can leak even if it appears to close. Could be caused by a weak or short spring too. A cylinder can be low on compression from a broken or badly worn piston ring. Do the compression test and if one tests low, squirt some crankcase oil into the cylinder and see if that improves the compression. Oil usually does improve poor compression if the problem is piston rings but not if the problem is a valve not sealing.
Gerald J. |
Post Reply ![]() |
Page 12> |
