Tractor Oil
domseb0 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote domseb0 Quote  Post ReplyReply Direct Link To This Post Topic: Tractor Oil
    Posted: 08 Mar 2018 at 12:00pm
You guys on this site always have the best info so here it goes. I have some older tractors in my fleet that have always used 30w oil for years but all my new tractors and skidsteers use 15w40, Dad always said never use multi grade in the old girls. What do you guys think ?? Thanks
WD45,Ford 801, Ford 1801, Farmall H, Case VA, JD790 case 1070,IH 3288, XT190, case 430/530/730 Massey 4709M
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 7:28am
Read this article for the best answer, IMO.
https://www.fillingstation.com/articles/earlyengineoil.htm
I don't know what was used in my tractors before I got them, so I use multi grade oil and changed it often at first. Get things cleaned out and go.
Edited by CTuckerNWIL - 09 Mar 2018 at 7:30am
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 8:16am
i do the same as CTucker.
I ain't gonna follow that Lucas oil guy to the cash register.  LOL
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 8:40am
Why did you start 2 threads with the exact same question???
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 8:44am
Walmart 15-40 in all of them from Homesteader all the way up.
They are 50 years or more old and the oil is certified by the same sanctioning body as the premium brands.  I save 20 bucks or more on a 5 gallon pail.
Tractors do fine and I don't go broke.
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 1:28pm
I run the new multi-weight in all my old tractors. Far superior to anything that was available at the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 3:32pm
One was moved here because it was in the wrong forum.
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 6:18pm
I agree with the "fillingstation" post.  It's not the viscosity, it's the detergent.  If the engine has been run on a nondetergent oil for years and has stored up a bunch of sludge, you are better off to leave that sludge in place by staying with a nondetergent oil if available.  I advised someone to switch at one one time only to have a good running engine start burning oil.  If you rebuild and start with a clean engine, that's different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 5:54pm
"your experience may vary"....
