New to me WD
Jordan.fleming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan.fleming Quote  Post ReplyReply Direct Link To This Post Topic: New to me WD
    Posted: 15 Feb 2018 at 1:01pm
Hey new to the forum, wondering if I could get some info on a problem with a wd I am work on. The issue is the hand clutch will engage but not snap over and stay engaged, any body else had this issue ?
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2018 at 1:21pm
I am not an expert nor mechanic....think it has to do with shims in there somewhere... someone will jump in and give you more details...hopefully before the sun sets.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2018 at 1:55pm
I second the shims, based on what I've heard about these clutches. There's a good video on You Tube showing the adjusting process, but I can't remember if it's for a WD or D series.
Like Floyd said, someone who knows more will chime in.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2018 at 2:11pm
Hi Jordan - fellow Ontarian - Welcome to the Forum.
It could be a 'shim' issue, OR it could be a very large snap ring in the clutch assembly has come off.
Here is a link to an 'on line' Service Manual for WD
Have a look at page 34.
Gary
PS you'll probably have to register to GrandpasTractors to view it
file:///C:/Users/Gary/Documents/Allis%20Manuals%20(GrandpasTractors)/05%20S1%20%20%20%20WD%20%20WD-45%20%20Service%20%20%20part%201%20%20%20P.%201%20to%2078.pdf
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2018 at 2:13pm
Look on you tube under Allis Chalmers WD hand clutch
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan.fleming Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2018 at 4:19pm
Thanks guys i will pop the cover off and double check the snap ring  is in place if it is i will take a look at the shims. I will check out that youtube video and the service manual aswell
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2018 at 7:18pm
may haft to take a few shims out to get a good snap to the clutch again' it will work a lot better.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2018 at 8:44pm
if the snap ring came off,dont tear the tractor apart,those rings get weak after 50 or so years.it can be progressively installed and tack welded in place.if you have to remove shims.there is a dimension called out in the manual,but cant recall it as of now.when you remove the shims,be SURE line the cavity with a large  bath towel to prevent loosing a shim pak or a bolt and washer,where it will go is only ia WAG.....I always adjust mine by feel,when you get a good positive snap after removing a spefic amount of shims,you are there.....
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 10:44am
I have seen linkage pins come out and cause this problem too. If you are lucky taking a few shims out will solve your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan.fleming Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 5:43pm
IBWD MIke View Drop Down could you elaborate more on the linkage issue the snap ring is definitely there everything seems to look and function right as i move the clutch with the cover off hoping removing shims will do the trick but if not is there some i can visibly see that would indicate the linkage issue you have mentioned
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 11:26am
On my wide front WD45, when I converted it from propane to gas I found one of the 'link pins' missing. I believe the ears were broken too. Will try to get some pics on here later today. I had lots of pics on here about this but thanks to the photobucket debacle they went away.
It sounds like removing some shims will solve your problem. If you have or can get a service manual for WD&WD45 it explains this very nicely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan.fleming Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 4:59pm
Great thanks for the info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:12pm
overcenter link pins.....usually when you loose a link it inverably gets into the pto intermediate gear and really makes a mess of things.i have replaced 3 pto intermediate gears and 1 case where the gear came through the side of ir all due to the overcenter link pin came out.these were all on other peoples tractors,and its no fun job.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:20pm
Picture attempt; You can see the broken 'ear' in this shot. I think this is the clutch that came out of my wide front 45. Not sure if the ear broke and the pin left or vice versa, but it needed replaced one way or the other.
Edited by IBWD MIke - 17 Feb 2018 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:28pm
Here is a shot of the whole clutch less the shims. Since it is a 3 disc unit it has the solid shim that a 2 disc doesn't have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 10:21pm
never saw an ear broken off like that
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 9:15am
I couldn't find a video on the in-tractor adjustment but this video shows the process of rebuilding and  out of tractor adjustment of the clutch.
This will give you insight on how it works.
Thanks to Dennis Anderson, a frequent poster on here.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 12:02pm
I'll second this note in a BIG WAY-  I had one make the trip out of the clutch pack and go all the way through, and it wrecked the intermediate gear.  Not impossible to correct in-situ, but you'd best have a 5-gallon bucket of profanity on-hand, and a second 5-gallon bucket and cuss-shovel scrape up all the profanity when you're done.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 5:39pm
pto gear had a guy bring me one that the pto int gear exited out the side of the case and landed in the field.happened on a 45 diesel.not too bad pullig a gas engine,but that diesel will make you utter words that never existed.....
