PTO output shaft question
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: PTO output shaft question
    Posted: 28 Jan 2018 at 4:17pm
How do I hold this PTO adapter onto the PTO output shaft of my B?  The hole in the shaft on the B is really small (less than 1/4 inch).  Is this just a cotter pin or something?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 4:22pm
not trying to be a smart guy but I'd have thought a PTO pin would fit. I just checked mine, all are 1/4" or BIGGER.
I'd try a big fat cotter pin, well oiled or greased..or an SS bolt/nut combo.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 5:14pm
Really small bolt (less than 1/4 inch).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 5:31pm
I'd just drill the hole out to 1/4", Its not like its pulling 200 HP, at thousands of RPM...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 5:37pm
Thanks all.  I'm new to this adapter thing and I wasn't sure how secure it had to be.  I'll get a pin or bolt to go in there.
1940 B "Lucy"
1972 314H
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 6:36pm
Mine uses a 1/4" bolt. Roll pin should work as well. Just make sure it's good and snug.
AaronSEIA
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 7:23am
Like the guys said....you just have to hold it "on", it's not transmitting power.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 9:31am
You need to keep the telescoping shaft well lubed, because when it slides in and out it pushes and pulls on that adaptor, which will wear the pin holding it on.
Dusty
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 9:50am
The hardest time for that retaining pin is when the implement swings to the side and compresses the sliding joint in the PTO shaft between the U joints as far as it will go then it pushes on that pin and can shear it. It is important that the PTO shaft between the U joints can get short enough for that condition without pushing on the retaining pin. If its too long it can break the tractor's PTO shaft or the tractor end U joint.
Gerald J.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 9:56am
when using a drawbar pulled implement you may need to use the sae hitch as the pto extension could cause binding as said previously.  I have an over running coupler on my c and its too long to run my grinder when hitched to oe drawbar
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 10:33am
Get an extension adapter that has a quick coupler end on it like what is on your PTO Shaft end.  Be safe...Dale
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 11:09am
Your tractor's operator manual (OM) should contain any pto advise. But sometimes an OM isn't available or some older tractor's OM did not advise much? If it helps, here is a weblink that gives ballpark dimensions for proper tractor pto / drawbar setups.
https://articles.extension.org/sites/default/files/English%20Task%20Sheets%20Group%206.pdf
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 11:27am
X2
This page was generated in 0.425 seconds.
