6060 Clutch
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 6060 Clutch
    Posted: 29 Nov 2017 at 6:28am
More 6060 Clutch Woes.
After getting the new clutch in, everything buttoned up, set clutch play per manual, started it up and the clutch will not disengage.
You can feel the pedal press the fingers in but that is it. I can start it in gear and the tractor moves and I can't stop it.
We tried the pedal adjustment each way but it did not help it.
Installed I measured the clutch fingers and they were right at the 4.8" per the manual (If I remember the dim right)
Any ideas why it will not release? Put it in gear and hold the brakes and see if that releases it?
PTO will engage and disengage fine
Charlie
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 6:47am
Sounds like a bent clutch disc. You won't know, until you take it back apart, which sounds to me like that's what needs to be done. Rick
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 6:51am
Did you have any trouble getting the unit aligned and the input shaft into the splines of the main drive disc? It don't take much as a person thinks to bend a disc...even with a little weight hanging on it can distort the disc, causing what you describe.   Rick
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 7:17am
I have to agree with Rick. I had this happen on a Massey Ferguson 2 stage clutch. Had to take it back apart on my dime and disc was warped. I didn’t think it went together hard but it doesn’t take much to bend it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 7:47am
The first time it was a pain trying to get it together as we didn't have the PTO shaft back far enough. Pulled apart, corrected that, and it went right together.
We are using guide rods so that it holds alignment.
I guess our first attempt may not have had it aligned and put pressure against the disk
Charlie
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 8:08am
Charlie...If you want to send the unit to me to repair the clutch disc/discs, just let me know and I would do that for you and the only cost there would be, would be to repair/replace the clutch discs. Rick
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 9:24am
Did you have a line up tool when you bolted it to the flywheel?
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 9:24am
Wrong pictures in previous post.
Could be the release bearing fork set screw loose?
Edited by LB0442 - 29 Nov 2017 at 9:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 9:27am
Here is a picture of the forks, set screw is on the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 9:29am
Forgot to mention those pictures are from a 6080.  Not sure if it is the same as a 6060.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 9:33am
That's the PTO lever adjustment.
Foot clutch is our issue
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 9:34am
Yes we did.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 9:35am
Thanks Rick
Is there a easy way to check the disk to see if it is bent? I'd hate to send it back and find out that was not it.
Need to set aside a few hours again....
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 9:42am
Yup your right, got to posting things and not thinking about it, too much of a rush.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 10:25am
Charlie the first one i did did the same exact thing I had bent the disc just a little and it wouldn't release broke her back down did it again little over 6000 hrs on this clutch over 5000 on original clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 10:33am
We got 1300 hrs on the original clutch. Some others in this area only got less than a 1000 hours out of them, Weak design or something...
I guess practice makes perfect.
Charlie
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 11:20am
I am at 12,000 hrs on my 6060 clutch.  For about 4000 of that it had a loader on it and did all the manure loading here.  The best tractor we have owned!
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 11:29am
Yeah...Charlie, if it looks like a soup bowl when you take it out (in the center where the splined hub is), then you'll know on the inside disc that it's bent. The one that lays on the flywheel can be checked by laying it on the pressure plate and checking each side. If it jumps back up at ya', then it's bent. It's pretty elementary, really.   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2017 at 12:02pm
This is a early model, I wonder if anything was changed on the later ones?
Oh well...embrace the suck.
Charlie
This page was generated in 0.273 seconds.
