Question - L306 mower washers underneath (?)
cdon_FL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Topic: Question - L306 mower washers underneath (?)
    Posted: 26 Nov 2017 at 2:32pm
Can somebody give me a summary of the purpose / usefulness etc of the thin washers that are stacked between the big flat washer and the blades under the deck on my Woods L306 mower ?
One of my blades slips in high grass.  and the bolt seems as tight on that one as the other two.
is it true that those thin washers can get "burned" and lose their spring / clamping temper ?  is that the purpose of them ?  Are they little "clutches" on each blade ?  or just spacers / height adjusters?
is there a good work around for this issue ?  If I have to put them back on, does anybody have a part number for replacements?  And what is the correct order of assembly under there?
Chris in NE Florida
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 3:13pm
Chris,
There is a sequence of washers and felt washers on the L306 (different on the L59).  I just bought 3 complete sets of everything from Messick's for mine.  The sequence permits the blade to slip if you hit a hard, immovable object.  I have all the parts numbers in my manual.  I'll look them up and post a little later.  I probably have two complete sets that came off my mower.  I'll check to see what I have and let you know when I get the parts numbers.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 4:25pm
Last time I bought woods blades they came with new lh thread bolts spring washers and slip washers
Edited by Dakota Dave - 26 Nov 2017 at 4:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 6:32pm
Yep, Steve's got it.....you need to go to a dealer to get them and you GOTTA have them.
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 7:36pm
My mower has a decal showing the order of assembly. Part #13409 shoulder washer, part #13402 clutch disc 3", part #13403 blade stop, part #13404 blade, part #13405 shim washer as required, part #13401 cup washer 2 required, part #12313 5/8" sleeve, part #13451 heat treated washer, part #24184 2 3/8" LH thread bolt. It is my understanding the shim washers are required to keep blade from slipping. I ordered my parts from German-Bliss, fast shipping and good folks to do business with. I also picked up some parts from my local Woods dealer. They should have these parts in stock or can get them quickly.
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 7:48pm
Thanks rustyorange for posting this.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 11:33pm
https://store.germanbliss.com/woods-l306-bmc-undermount-mid-mount-rotary-cutter-spindle-and-blades-assembly-parts
thanks, All.
Above link shows close up of the assembly with part numbers.
Chris in NE Florida
