da 6265 brake bleed
cob_crusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cob_crusher Quote  Post ReplyReply Direct Link To This Post Topic: da 6265 brake bleed
    Posted: 05 Nov 2017 at 7:31am
have deutz 6265 and o/h both master brake cylinders. they were 20 mm made by FAG and finally got correct o/h kit. this is a looped system (similiar master slave). i used mighty vac to pull fluid thru system. sequence was right master, right brake, left brake.
(left master has no bleeder). when i did left brake, i applied a little from right peddle and then did left foot peddle.  results were left peddle ok but right was still spongy. in both peddles i get a small minute amount of air bubbles.  i rechecked lines for leaks and tightened. i put grease around bleeder outside and am cracking bleeder and slowly depressing peddle, tightening bleeder and then slowly releasing peddle. any ideas how i can find where air is coming from ? thanks
ac 200 7080 653 da d90.06 6265 f400 ol 77 1650 jd 4230. the reward of suffering is experience. ignorance is bliss. no muff too tuff. i am only responsible for everything. free whiskey naked women.
This page was generated in 0.387 seconds.
