Lift Arm Latches |
ddlong
Joined: 22 Jul 2012 Location: Thompson IA Points: 82 |
Topic: Lift Arm LatchesPosted: 31 Oct 2017 at 6:09am |
https://images.craigslist.org/00V0V_hj4X5eJVIG4_600x450.jpg
Are there different size latches for the lift arms for the Snap Coupler system? Will WD/WD45 fit D14/15/17/19? It looks like the CA/B arms are a different size? Going to need a set for a WD45. Don in Hawkeye MO |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24882 |
Posted: 31 Oct 2017 at 6:11am |
Pretty sure they all fit, evrything.
Those are the newer, heavy duty ones.... .. the hole allows a 1.25" bar to be installed to keep things from breaking I think. wait 5 minutes and 4 guys will have 3 imore replies !! Jay |
Larry in NC
Posted: 31 Oct 2017 at 7:10am |
B, CA, D10 and D12 are the same and are different from WD WD45 and the other D series tractors.
ddlong
Posted: 31 Oct 2017 at 7:32am |
That’s what I thought. The latch itself is the same as all the Snap Coupler emplements use the same size bar to go into the latches.
Don |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 31 Oct 2017 at 7:48am |
I have two or three sets for the WD45 tractors.
Brian G. NY
Posted: 31 Oct 2017 at 9:26am |
I did a little research on this issue a few years ago.
This is what I found out.....I think I got it right! As stated, the CA, D-10, etc use a different style coupler. The 3 photos show what I think are the latest and heaviest latches; probably for the 175 and up tractors altho they should fit the WD-WD-45s as well. The last photo shows a comparison and the extra "meat" in the casting of the HD unit. ![]() |
JimD
Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Posted: 31 Oct 2017 at 9:30am |
I've got a few sets left also.
We have new and used parts. 877-378-6543 |
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 13 Dec 2021 at 10:04am |
The D17 would probably have used the #4 lighter couplers with the spreader bar. I would imagine the #5 came out about 61 with the D19, a heavier tractor, and was carried through to the snap coupler versions of the 190. JMO.
DrAllis
Posted: 13 Dec 2021 at 10:16am |
Dad's 1967 series 4 had the later/thicker latches, same as D-19 and 190.
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3162 |
Posted: 13 Dec 2021 at 12:17pm |
My Series 1 D 15 has lift latches similar to the picture . What goes in the round hole ? A spreader bar ? What purpose would that be ? THANKS !!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8734 |
Posted: 13 Dec 2021 at 12:26pm |
I think it just stabilized things more. Dad bought a SC plow for WD in mid 60s. Put SC hitch on and bought new arm latches. They are the heaviest latest version. I'm sure they superceded everything before.
ACinSC
Posted: 13 Dec 2021 at 1:24pm |
Thanks Steve , maybe other tractors are different but on my D 15 I don't see how anything could move unless something broke ? Maybe the lift latch could slip off the end of the lift arm ? THANKS again !
Robert Musgrave
Silver Level Access
Joined: 11 Sep 2009 Location: SE Wisconsin Points: 243 |
Posted: 13 Dec 2021 at 5:31pm |
Those heavy-duty lift latches showed up when the "big disc" (13.5') snap-coupler with a chain attached to lift arms and the pulley was on the snap-coupler tongue to activate the Traction Booster. The WD-45 had a D-17 upgrade and duals--it was all it could handle. One of the neighbor BTO's of that era had a 190 that I believed only pulled an 11-foot disc. At least that was the way it was on our farm. If you were used to your foot being on the rear platform; you had to be careful you didn't snag your work shoe when lifting or lowering an implement! R. Musgrave
