6060 3 pt wont raise |
Post Reply ![]() |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Sep 2017 at 11:29am |
Got a 6060 that I took the bottom screen filter out and cleaned it up, shortly after that the 3 pt got funny sometimes would raise sometimes not; now it quit raising completely, cables all move freely, I unhooked them moved the whatchamagittit by hand and nothing differt, whats the best way to get access to the valve? Thinking dirt or something moved around and lodged in the valve ??!!
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Air bubble?
No doubt that, wish tho, been running it for a bit like this, would have thought it would've worked out by now
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21955 |
If the remote outlets don't work either, it's a pump issue. Does the Power steering work???????????
Everything else works good,,, has a loader on it works fine
Edited by DougG - 30 Sep 2017 at 6:56pm |
Both levers have to be all the way rearward for hitch to raise.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Remove seat and plate to access valve. There is a plug that takes about a 15/16 socket. Under it is a spool about 1" in dial. And about 1 1/2 long. Lift it out, clean it and seat. Should work. MACK
Ill try that Mack thanks
sherman ![]() Bronze Level ![]() Joined: 18 Oct 2009 Points: 22 |
i had issues with my 3pt on my 6080 a few years ago, check your filter and the sealing orings on it. its a red filter and the o ring has to seat proper, mine was not and it was sucking air, sometimes it would work sometimes not. you can also have 2 orings in there if the last guy did not remove one. hope that helps.
Post Reply ![]() |
