This folks is why we don't use 2 in nylon straps
Bradleytrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Topic: This folks is why we don't use 2 in nylon straps
    Posted: 21 Sep 2017 at 3:12pm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 3:20pm
YIKES!
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 3:28pm
No way is that gonna buff out!
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 3:37pm
The straps, chains, or whatever are a concern, but what about the braking of the entire unit?  Looks like he did a mark on the car in front as well?  Did the trailer brakes work????
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 3:47pm
Straps Can work if a guy knows how to use them. Wrapping the nylon strap around a piece of metal is NOT how you use them. Oh yea, there are way more junk straps out there than there are good ones too. You get what you pay for.
I still chain my tractor.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 4:06pm
I'm a chain guy also, The above photo is a good example of why we all need to do a good job  securing our loads and that is we could easily get killed by our tractor when it joins us in the front seat. In other words we should look at it selfishly .
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 4:51pm
Heck he didn't need the trailer, hope he's got a good set of ramps to unload it.
Cernunnos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cernunnos Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 5:13pm
That Ford has a good set of rear springs...doesn't even sag! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 5:39pm
Heck, and they said you can only get a Model G in the back of a pickup! Well, I beg to differ now! All kiddin' aside, big Tractors Chains n' binders all four corners. Garden Tractors can be strapped down. BUT, all four corners! I believe Jersey is 6 tie downs for heavy equip. now. I'll havta' check that, but I think that's what we have to do....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 6:10pm
See it all the time on I44, straps have there place, but not on tractors,, capital Dumass doing this job
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 6:11pm
That is EXACTLY why i have ALWAYS used chains on any tractor i haul!!!!!As steve said for chains and four binders per tractor!!!!!It's not just your own safety but the safety of others on the road and others in the cab with you!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 6:15pm
Car in front is a write off, truck too. Tractor and trailer look like the only survivors. Sure hope no one was hurt. I zoomed up the picture, car ain't pretty.
Sad really, even ONE chain and binder on the back to the tractor might have prevented it.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 6:26pm
I betcha his face was red, and his shorts wuz brown...Wink
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 6:51pm
I looked it up. FMCSA regs state minimum of 4 tie downs with a WLL of 5,000 lbs and the total WLL of the tie downs has to equal at least 50% of the load weight. Nothing on what I read about chains VS straps. Technically 4 2" straps would qualify on most of what collectors haul.
AaronSEIA
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 7:31pm
Guess he's getting ready to load the 2nd tractor on the trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 8:16pm
Thank God for that topper or it would have been in the cab|
Chains and ratchet binders. My 720. Is the. Only thing that gets 2" ratchet straps. Rated at 5,000 lbs
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 9:44pm
I'm a chain guy as well, except I still use the lever-type boomers. Some say they're unsafe, but I always wrap the chain around the boomer and wire it in place.
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 10:13pm
I'm going to disagree with you on this. Chains are more foolproof, but not much safer. Sharp edges don't matter to a chain, they matter a lot to a strap. If you strap the tractor down without putting the strap over any sharp edges, they will hold what they're rated to hold. One thing to consider too, whether using a chain or a strap, is that the straps on each end of the tractor should be rated for the weight of the tractor, because 2 of the chains/straps aren't doing anything when you rear end somebody. That said, If I had the option between using chains or straps, I'll take the chains. I have so many straps around, that when I do haul something, I over secure it anyways, so catastrophic failure isn't likely.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 6:17am
I'm a bit with Joe.  Plenty of people using junk chains too, that have been stretched, spliced, welded, cotter pins about to fall out of where the hook attaches....A little more forgiving, yes, and yes the best choice, but not necessarily by a lot.
That topper helped maybe a little, but not a whole lot.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 7:05am
The truck rear-ended the truck in front. That scene wasn't going to play out well, no matter how the tractor was tied down. The tie down chain or strap is only as good as the tie down point. Unless the tie point on the trailer is factory welded, I wonder how strong it would be if it had to hold an impact like that?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 7:27am
What are you guys talking about?  No one ever told me I needed to strap it down but I sure I can find some rope around here......  Hey that guys got no worries, it's the guy who stopped in front of him.  He's at fault.LOL
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 7:33am
I dont see parts of straps in the picture either. if the straps fail the ends would still be attached,  throwing one chain over would not have held any better than the one strap did. I use two chains or two straps on both ends. straps must be tight and attached to fixed points or chains on each end. looping a chain over the draw bar will ruin the chain just not as noticable as it ruins a strap. Ive tied thousands of tons of cargo on aircraft. using both straps and chains. either will hold the load if used properly.
Edited by Dakota Dave - 22 Sep 2017 at 7:34am
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 7:35am
around these parts if you rearend someone your at fault for not paying attention unless you can prove his brake lights were not functional!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 7:40am
Yep!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 7:50am
Not sure how this picture determines that straps were at fault.
Charlie
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 11:01am
was the brake set? (not sure if that can even be done on this tractor)
was it left in gear?
having done these two things alone would have helped it not to roll forward (IMO)
i use straps (so not to destroy the paint), set the brakes and leave the transmission in gear when i haul my restored tractors, and so far have never had any trouble.
also if you look at the deck of the trailer in the picture you can see a green strap.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 11:05am
it also strange that the tailgate is down and not smashed into the bed of the truck.
dan
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 11:11am
Depending on what happened in front of the truck they will go after the truck for inattentive driving or following to close, unless a dash cam or witnesses prove that he was cut off by the car.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 11:20am
At least that Ford has a good engine in it now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 11:58am
OK, so we see 1 strap, so that means the load was secured that way?
Too many people here guessing what happened.
Charlie
This page was generated in 0.079 seconds.
