7040 PD transmission filters |
jazzsuds
Topic: 7040 PD transmission filtersPosted: 13 Sep 2017 at 11:05am |
I have a 7040 PD and need your help in identifying the part number for the transmission filter and where it is located and is there one or two filters?
Thanks
lowell66dart
Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Thanks(1)
Posted: 13 Sep 2017 at 1:03pm |
Go to AGCO parts books and log in as a guest. Search for your tractor and this will tell you what you need. Good place to buy a manual too. Good luck.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
REEDE
Thanks(1)
Posted: 13 Sep 2017 at 6:47pm |
The AGCO filter # is 70267600 for the PD transmission.
Dans 7080
Thanks(1)
Posted: 13 Sep 2017 at 8:28pm |
There are two filters. Bottom side of trans one on each side behind round covers. Make sure they go back together the was they came apart. I can get part numbers tomorrow.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Thanks(1)
Posted: 13 Sep 2017 at 9:53pm |
Dan is describing the hydraulic filters in the belly of the rear end. The transmission filter if located behind the left hand engine frame rail. It is a spin on type. There is also a screen under a plate right behind the hydraulic pumps that should occasionally be cleaned.
Edited by Lynn Marshall - 13 Sep 2017 at 9:56pm |
jazzsuds
Posted: 13 Nov 2017 at 11:58am |
I also have a 7040 with power director and when I took off the transmission plate behind the hyraulic pump there was supposed to be a screen to clean and put back on but instead I found a filter not a screen. Anybody know why and what the part number is?
MACK
Posted: 13 Nov 2017 at 10:04pm |
A filter on suction side would restrict oil flow to pump with cold oil. MACK
jazzsuds
Posted: 05 Jan 2018 at 8:37am |
Anyone know what the part number is for the screen filter I found underside behind the hydraulic pump behind a plate that had 6 bolts holding it on? The Allis parts diagram doesn't show it.
Edited by jazzsuds - 05 Jan 2018 at 8:38am |
DrAllis
Posted: 05 Jan 2018 at 9:01am |
70253478 is the suction screen. It is not a paper filter, it is a screen that can be washed out and cleaned. Used on models 7010 thru 7080 and 8010 thru 8070.
jazzsuds
Posted: 05 Jan 2018 at 10:37am |
Thanks
