Char Lynn 101F
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Topic: Char Lynn 101F
    Posted: 07 Sep 2017 at 11:46am
I have a Charl Lynn power steering motor that has 7/8" shafts that are leaking. The OD of the seal is 1-1/8".
The motor has model 101F stamped on it. There is also 371 stamped on it.
I order Eaton kit 21122-00 but it has 1" seals. Any idea who would have the correct ones?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2017 at 12:47pm
Try Motion industrial
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2017 at 9:36pm
Go to your local auto supply or implement dealer with old Orings. They are a standard oring. Match them up.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2017 at 6:40pm
I went to a hydraulic shop and got two 7/8"x 1-1/8" quad rings. That is what Eaton shows in the assembly paperwork I found.
