WD45 ground driven pto
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: WD45 ground driven pto
    Posted: 25 Aug 2017 at 8:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 8:12am
Then they had to paint it green
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 9:15am
I'm thinking it's a straight stick WD rear end. There is a place to bolt up the regular PTO box on the bottom of the transmission, so it would be just like a WC configuration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 9:19am
Maybe built for the Amish or other 'no engines' group ??
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 9:21am
A load on the tongue and a jerk from the horse might have the driver lookin at the sky. Looks pretty short and light on the front.
Leon B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 9:49am
I saw a similar design at a draft horse symposium about ten years ago in Minnesota.
Gerald J.
Edited by Gerald J. - 25 Aug 2017 at 9:49am
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 11:08am
How close are they getting to 540 on the shaft? I guess if you plug the spreader you just put the horse in reverse?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 12:07pm
The PTO would run the fastest in low gear and the slowest in 4th gear when being driven by the rear wheels.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 12:16pm
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 1:28pm
This is sort of a rube goldberg way of doing it. The only real benefit is that you don't need gasoline. I've seen horse-drawn power units that attached to balers and forage choppers. The Amish do it that way. I've seen them use WCs for belt power. They'd drag the tractor into position using a horse. It would have been easier to just leave the engine in place and pull the tractor, baler and wagon with a team of horses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 1:46pm
Yes, that is why I only posted link & not picture. Maybe that's the only paint they had around? I like Gerald J's picture better.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 2:36pm
I bet that bailer would pull hard for a split second each time that plunger hit. Think what the governor does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 10:07pm
Bet they get good emissions too
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 10:11pm
Horses emit ethane gas and used horse hay as manure. Not zero emissions at all. Also contaminated liquid and exhale carbon dioxide which some claim is the worst green house gas. Of course plants take in carbon dioxide and breath out the oxygen we and the horses need to survive.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 10:14pm
You know I was kidding right
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 1:31am
I sold a couple of WD tractors with no motors years ago to guys wanting to pull them with
horses.I think it was Small Farmers Journal came out with an article on a converted WD
back in the 80's got the idea going.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 7:10pm
Amish won't use anything on rubber.
It would be hell grinding a load of corn using that!  I guess people don't probably do that anymore!
