8070 fuel tank drain plug leaking.
Kevin(Alabama) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Topic: 8070 fuel tank drain plug leaking.
    Posted: 17 Aug 2017 at 6:23pm
Okay I reworked 8070 to show condition I also use for farm work. When I had tanks off about three or four years ago I replaced the drain plugs because they were dry rotted.i have replaced with many new plugs from dealership at eighty something dollars a lick. They will not hold up. I will tighten them and in a day or two the rubber splits and fuel leaks or I have had them to come completely out and lose all the fuel it tank. Okay I thought I may be over tightening them so I pushed in and tightened just a little where it would not come out and add some fuel and crawl under and tighten a little at a time till it stops leaking. Well give it a few days and it is leaking again so tighten some more a few days and leaking again finally it splits and it's time to get another. I have used boat plugs and rubber freeze plugs they work good till a few days and the rubber in them gets soft and they come out. I keep a couple of them at all times to temporary fix the AGCO plugs that come out of course the fuel runs all over you when you change them out in the field. I have now plugged one tank completely off where I have only one plug to deal with. I'm ready to take tanks off and tie a bucket to the tractor. Any ideals how to fix this or replace plugs with? Or anyone else have this problem?
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 6:27pm
Can you convert to steel? Or adapt the tank to a steel fitting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 6:41pm
No it's plastic and about 1/8th thick with no threads. You push plug in and a bolt tightens the rubber and it swells to seal the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 6:47pm
May have to go to the maroon belly 7000s steel tank. But I would rather not. I may have one tank that hasn't leaked in a few weeks so I may have it sealed but too with one tank it will not get though day on fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 7:13pm
Is the hole that the plug fits into nice and smooth? A burr or ridge could possibly cause a small leak, so would a hairline crack in the tank fitting where the plug goes in. Also if the plug extends just a bit past the bottom of the tank it will seal better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 8:45pm
A bulkhead fitting might work, if you can figger out a way to get at the inside of the tank, to hold the nut...  Or, drill out the hole to fit a valve stem, fish a valve stem down to the hole, and pull it through, with a valve stem pulling tool...
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 9:05pm
How big is the hole most freeze plugs. And boat plugs are not designed for oil and will always get soft and leak go find a hydraulic bulk head fitting it will have oil resistant gaskets on them find the ones that are blind that will have a spot on the out side to put a wrench to tighten the jam nut do not turn the fitting just the nut use a stiff wire to fish from the plug out the cap then just drop the fitting down the wire put nut on remove wire teflon up a metal plug and no more problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 9:06pm
Dave, the hole is alittle big for a valve stem and I don't think the valve stem will hold up with the Diesel fuel . It will be like the boat plug or the rubber freeze plugs. Don't know what the AGCO plugs are made of but fuel don't bother them but they split and leak.
Hubert, I don't see any crack or burr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 9:15pm
Okay Bradley I'll see if I can find a fitting that will work but the tank that is now giving trouble now is the tank without a opening on top But I'll see if I can find a way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 9:00am
Put about 15 ft of small soft rope in top of the tank ( tie the end to something) then dump about 5 gallons fuel in an let it run out the bottom most of the time the rope will float to the hole may take couple tries once it's end is out then you can put the fitting on the rope and send it on down to the bottom
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 11:34pm
The rest of us with 8000 series plastic fuel tanks are reading this thread in nervous anxiety wondering how long our plugs are going to last…?
Mine are cracked too, but still holding.
How about putting some fuel tank repair glue on the plug prior to install?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 12:50am
Wouldn't hurt to try. Another thing these plugs from AGCO are getting harder to find. Maybe cause I used them up. LOL.   But I bought from two differant dealers and both had to get from other dealers and the last had to be back ordered and after a couple of months I got it in. I was thinking they may be getting old and that's why I'm having trouble with them. I'm gonna try to come up with something. Maybe try the hyd. Bulkhead with plug.
Edited by Kevin(Alabama) - 19 Aug 2017 at 12:51am
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 8:16am
Or aftermarket/ custom fuel tank???
fuel tank
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 11:33am
can these tank be threaded ?         or else a expanding plug with buna instead of neoprean  rubber.          that dixon company that does sanitary and chemical valves and fittings could probley lead you the right direction
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 5:48pm
Another way to snake in fittings is to use an easy-reacher, up, from the bottom, and out the fill cap... also could use a wire fishing tool, like the 'lectricians do...Wink
Here's a link to a 4' mechanical pickup tool, AKA LDAP (long distance a$$ pincher!):
Click below the $39.57, or the connect to tooltopia button,  to see the LDAP
Edited by DiyDave - 19 Aug 2017 at 5:51pm
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 1:46am
Hey Kevin. Good to hear from you again. It's been a while since I've seen a post from you. Glad to hear that you have that 8070 just the way you like it, but sorry to hear about the fuel tank leaks. Never heard of that happening before. I'll take a look at mine some time tomorrow, and see what kind of plugs it has. I hope it doesn't start having this issue. My black belly 7060 has plastic tanks, too, and it was leaking fuel when it was plum full. But we found a hole in the top of the tank that wasn't plugged. It was a factory, round hole, and don't know what was supposed to be there, but being on the very top, and only having to hold back a little sloshing, we put a piece of duct tape over it. I know that is not a good fix, but we were out in the field when we discovered the hole, and it was a "make do with what you have" situation. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 8:26pm
Yeah I've been quite for a while. I toke the tanks off when I rebuilt the transmission. I seen they were dry rotten and thought, I don't need to put these back so I poped them out and put new ones in and they have been a problem ever since. That's been four or five years ago.
Not only they leak but sometimes they come come completely out and usually over night. Makes big mess when tanks full. I thought I was installing wrong but I have tried ever way you can and they still leak. So I'll have to try some of the ideals these folks have thrown at me. Bad thing is there is no hole in the top of the tank that is leaking now. But I'll come up with something.
