D17 transmission questions
gerkendave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Topic: D17 transmission questions
    Posted: 13 Aug 2017 at 10:33pm
Hey everyone. Still searching for a good transmission to go into my series 4. Just curious if a tendon from an earlier series is the same or not. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 7:10am
If you are looking for a complete rear end/transmission assembly for a D-17 S4, it has to be from another S4 or a One-Seventy. What is wrong with yours??
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 8:26am
Thanks Dr! The one on mine is jumping second and third gears. It's bad enough on third that even after moving the shift detent you can't even hold it in with your hand under a load. Was hoping to find a 170 or factory three point 17 with a good transmission for less than the gears and bearings would add up to to fix mine.
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 8:41am
Series IV is the same whether factory 3 point or factory snap coupler...they interchange and either will bolt right up and be correct.
This page was generated in 0.044 seconds.
