3D printed sealed beam light adapters WC,WD
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Topic: 3D printed sealed beam light adapters WC,WD
    Posted: 10 Aug 2017 at 10:15pm
Have an abundant supply of sealed beam bulbs and need new lights on the WC I'm getting running. Nobody makes direct replacement sealed beams for the original housings. I have seen hose wrapped around sealed beams to take up the gap.
A little time on tinkercad and I drew up this adapter. I am 3D printing it now out of flexible black TPU filament. Will know Saturday if they fit when I'm back at the tractor.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 11:07pm
Awesome! Pretty soon we'll probably all be making our own parts if parts supply is discontinued.
Maybe the Minneapolis Moline guys will be the first ones to try that. Lol
Edited by CrestonM - 10 Aug 2017 at 11:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 10:59am
Here it is installed on the sealed beam. Took 4.5 hours to print it.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 2:09pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 3:24pm
Looks really good to me. Great solution. It's industries work like this that will help keep Allis alive well into the future.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 9:18am
Why does it take so long to print?  Are you going to sell them?  Price?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 1:51am
TPU needs to print at slower speeds. Also support material is needed to create the inside channel. All this takes added time.
I need to make a tweak to the model so it fits tighter when clamped. I didn't plan to go to production with these. Do you think there would be a market for them? What would someone be willing to pay? The lens, gasket, and reflector aren't that cheap if they are missing or damaged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 6:22am
What the 'media' never report is how LONG(zzzzzzzzzzzzzzzzzzzzzzzzz) 3D printers take to make 'stuff'. The 'computer' program is fast, it's the actual oozing out of plastic that takes time. They are good at prototype, one-of-a-kind or 'proof of concept' parts NOT  mass production.
As for the 'adapter ring', I'd look into a turret style CNC machine and use metal or plastic for the rings. You start out with a 'rod' or 'cylinder' then carve the inner grooves,outer, then part(cut off) the piece. Less than a minute per piece ONCE it's all set up.
It is nice to see something USEFUL made from a home 3d printer !
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 6:09am
  I think there'd be a market for them.  Guys who have working tractors would like to have sealed beams for seeing better when working at night.  But then sealed beams aren't cheap either.....
  There should be a market from guys with show tractors also if you couldn't see that gasket.  But then there are the nit pickers...........
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 8:39pm
I would take a set.  I want to change to LED bulbs but the sealed beam style doesn't fit like you said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 5:38pm
One more final tweak and I should have it. Need to fill in a slight gap on the clamp on the front of the ring. I am making it slightly thicker to take this gap up.
Edited by jbirnsch - 17 Aug 2017 at 5:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 9:09pm
Just started the print. Here is a short video from the first few layers.
Printing the sealed beam adapter video
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 5:39pm
Final version complete. This version took 6 hours to print with the support material needed to create the inside groove. I lowered the print temp and increased the top am bottom layers to 3 to fill any holes that were showing on the first version.
This page was generated in 0.291 seconds.
