L59 woods on a B
Dennis Mills View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis Mills Quote  Post ReplyReply Direct Link To This Post Topic: L59 woods on a B
    Posted: 31 Jul 2017 at 1:50pm
I need a couple photos of the rear bracket that goes between the final drive housings with an overall width. I have the bracket fo a C and want to narrow it as well as center the mower brackets. Thank you in advance
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 8:17pm
Dennis,
I have that set up on my B.  Can't get pics right now, but that has been shown on here before.  Try using the google and an image might come it.  I will get you some measurements if you tell me what you want.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis Mills Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 9:37pm
I am looking for a pic with measurements for the overall width and of the brackets that go to the mower location. My bracket had the mower offset to the starter side on the C. Thank you
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 11:05am
You just cut 6" off each end the mower is suposed to be offset to the right side.the pulley bracket needs to be in the same location in relationship to the belt pulley in order for the belt to run true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis Mills Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 11:44am
Thank you! I didn't realize the mowers were off set.
