Runs then quits
cedy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cedy Quote  Post ReplyReply Direct Link To This Post Topic: Runs then quits
    Posted: 30 Jul 2017 at 11:31am
Chalmers HD3 Runs for about 5 Min then quits If I let it sit for a few minutes it will start Its like its using only what is in the two filter containers Gas drains fast from tank but hose after filters dribbles should it run fast after filters Put new filters in Tractor sat for a few years when I got it  Any help would be nice This tractor is new to me
 Can someone tell me on the HD3 Diesel can you have a straight gas line to the injector pump reason I am asking this was not getting gas to run longer than 5 min so I took off what looks like a primer off the hose to the Filters and it would not let gas in fast . This primer does not look stock Looks like someone addid it . so now line to Filters and out to Injectors Is this OK ? Thank you
Edited by cedy - 30 Jul 2017 at 6:03pm
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 1:22pm
Dribbles should be enough to keep it running. Does it still quit after 5 mins even if left idling? Consider a defective coil too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 1:58pm
If it only trickles out the filtered side, your filters are plugged or fuel isn't getting to them fast enough. You should have a steady stream the size of a pencil running out the drain , on the bottom of your carb bowl.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 2:27pm
I'll second CT,,,,,, maybe the hose has come apart inside and it is plugging it up. I had that happen once and it wasn't fun to find it!
cedy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cedy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 3:13pm
Thanks but No carb, Desel engin I will try cleaning and replacing all hoses It has two filters so possibly the pass over for filters are plugged Thank you
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 3:36pm
most likely the return is plugging up with broken down flex ring material from inside the injection pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 10:15pm
Loosen the two screws on side of pump that holders timing window to pump. With a little fuel running out, see if it runs ok. If it does, take pump off and send it to I jpumpEd. The weight retainer in pump has come apart, plugging return on pump.      MACK
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 8:36am
We put a low pressure electric fuel pump on ours as old primer pump was missing when we got it. And we had trouble getting filters bled. Sounds like flex ring as Ed and Mack mentioned! We also had to have Ed rebuilt ours with same problem.
cedy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cedy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 1:04pm
Thank you all for the advice Did fix it it was the primer just took it off so gas can flow
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 9:21pm
If you keep feeding GAS to a diesel engine, you are going to have real problems soon Wink
