No till corn?
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: No till corn?
    Posted: 06 Jul 2017 at 11:39am
Has anyone had any luck with planting notill corn? I have planted beans this way before and had good luck. I was always told corn will take a slight yield hit though.   From what I read if you can get it a really early shot of n to get it boosted it helps it tremendously.   Something like 2x2 or starter. Looking to minimize my time during planting season and maximize my time with my family.   We have talked about getting out completely, keeping our own ground, keeping ours and a couple close fields, and going no till. Any ideas on realistic time savings by going to no till?
Thanks
Adam
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:47am
Its not as easy as it used to be with herbicide resistant weeds. Lots of marestail problems this year, once they are up you cant kill them. I like to till to start clean. Only way i would no till is into a cereal rye cover crop. Then you have the problems of not drying out in the spring enough to plant. Plus i have had many guys tell me the fall chisel plow gives a 20 bushel boost to corn.
Everyone tills here, no till just isnt consistant enough.
I plan to experiment with rye in the future.
I also have been eyeing a versatile 850 and a 30ft cultivator. Large equipment has gotten pretty cheap.
Edited by Dmpaul89 - 06 Jul 2017 at 11:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:53am
You mentioned cereal rye. If your interested in some seed I have about 60 bushel of cereal rye seed to sell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 12:15pm
Ill keep you in mind. If you happen to come this way let me know. May take some
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 12:20pm
just get bigger equipment. it don't hurt to have a 4x4 articulated tractor on 100 acres, it was cheaper than buying a 2-wh drive. then a bigger disk or FC. don't take long to do the field. then an 8-12 row planter, they are going cheap. as is bigger combines. that's how I kept my costs down and spent a lot less time in the fields so I could spend more time with the old lady....oooops...I mean the loving wife! also had more time for camping and just going out with friends! for the past 15 years small equipment has been bringing more money than big equipment on auctions! I've tried side by side field tests from til to no til for years, (9-10) and the til'd fields always yielded better on my soil. and a disking of field cultivating is cheaper weed control than chemicals!
Rick143 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 12:41pm
It has been tried in my area but now most of the farmers at least go in with a disc to break the top up. Beyond that it depends on what was planted the year before.
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 12:55pm
I've had very good luck with no-till using trash wipers with a coulter. But yes resident weeds are becoming more of a problem. Added chemical costs verses reduced fuel & less wear and tear on machinery. Reduced time in field mean's more time with livestock or family. Everyone's operation is different. You will need to decide what work's best for you.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 1:32pm
After about a decade of full tillage I built a three point sprayer and modified my planter for notill and notilled for about a decade.
By not having used glyphosate for its first decade I didn't develop any glyphosate resistant weeds. The plow coulters on the planter holding the thin ammonia knives are borrowed from my AC 2000 plow. The planter has Dawn Trash Whippers on each row unit to move bean straw or corn stover out of the way. These pictures show the rig as used notill. I applied 32% with the sprayer as the pump down the ammonia knives and side dressed later in the year.
The corn may have suffered a little the first year or two of notill but it recovered after that.
In 2007 I did an experiment where I shopped hard for a corn number that produced well with minimal nutrition, I think it was Crows 4221T. I spread 100 pounds of MAP giving 11 pounds of N, then I put down 60 pounds of N 2-1/4 inches from each row with the pictured planter and sprayer combination. I applied another 40 pounds of N by dribbling 32% every other row when the corn was about 4 feet tall. I had three varieties of seed in the field because the planter dropped an extra seed every 15 feet and I had to go to back up supplies. An Ottlie number seemed to get along with the treatment, but a Dyna-Gro number tipped back half the ear. It clearly didn't like the low N and high population (34,000 seeds per acre). The yield over the scale at the elevator was 173.2 bushels per acre. Not bad for 111 pounds of N.
The corn stover left from that crop made planting beans difficult in 2008, the ground didn't warm up or dry until mid June. I had used glyphosate for a weed burndown in mid May and had CPS apply Prowl H2O a week later. The weeds were all still brown mid June. Mid July I found fresh lambs quarter about 4" tall, so I got out the sprayer and found some patches had drowned out or I had gone around them being wet so I ordered so 0.9 maturity bean seed from Albert Lea Seed House and filled in the blank spots. Figured the least I would get was ground cover. At harvest the field was clean everywhere, but when I hand picked the beans from those planted in mid July, the beans were hard but the size of BBs so probably didn't contribute to the crop delivered to the elevator.
In 2009 I rented the place to a mostly corn on corn strip tiller and he has turned me a good profit every year. Our lease is 50/50 crop share. The strips warm up and dry and he hasn't had to plant very late because of cold wet ground. He did plant a little late this year wanting to avoid the corn getting bit by a late frost. Last I looked the field looked decent but not tall. I might to take a look this evening.
Gerald J.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 1:35pm
Hard to compare our area to other parts of the country, but if it wasn't for no tilled corn around here, there wouldn't be any corn. We have to make every drop of water count, and most years, the moisture you lose by tillage will be the deal breaker for profitable corn. This year, however, even no till is not even cutting it. But, if farmers around here had tilled this spring, we'd be re-living the dust bowl. But instead, there is at least enough growth and residue to hold the soil. Darrel
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 1:39pm
I do some no-till corn into bean stubble. I have the local co-op spray a burndown a couple weeks before planting to keep weeds down. The ground has to be pretty smooth and I slow down to 4mph or so whereas I may run 5 planting corn in a worked field.
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 5:18pm
If you have a decent planter it all depending on the ground. Clay is iffy loam or sand is fine.   If you don't have a Deere or Kinze forget it. On some of our lighter ground we have seen a gain.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 5:57pm
It depends on what soil type you have. Ive seen most types no tilled, vevy heavy clays and gimbo type soils are best to be worked. Most 1980 and newer planters shoild no till fine, just depends on their weight per row. It takes longer for ground being no tilled to warm up wich can be a set back, but in a dry year it helps. One big key is how to manage the weed resistance. Most around here burn downn a few weeks tp a week before planting, then come back with a second pass when its emerged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 6:22pm
It's a deere 7000 eight row.
Plowking77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowking77 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 8:51pm
We've been no-tilling for 20+ years here in NW Ohio an I think the yields r better,, you don't have the compaction like we use to when we would work it twice an then plant.. compaction kills you in r clay!!
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 9:24pm
Please try being rid of the no-til coulter on your planter. It's over-kill in most any soil classification (sand, silt, & clay). It can hair-pin crop residue directly into seed furrow, dig up excessively mucky soil that wraps up on gauge wheels which offsets proper seeding depth, & mixes dry soil from surface directly into the seed furrow.
Properly shimmed seed furrow opener disks will cut perfect furrows in even the worst conditions.
Adjustable Residue managers are a must. In addition, the floating residue depth wheels are also an excellent investment which keeps the residue fingers from over gouging too much soil.
Edited by AC7060IL - 06 Jul 2017 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 9:24pm
You have the right planter atleast.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 10:15pm
This year my no til corn looks the best and came up better than what was tilled. I also agree with ac7060 that you don't need the no til coulters. I have a 7000 Deere 12 row 30 "
with the heavy duty down pressure springs and it puts the corn in hard ground very well. In the past yields have been comparable with no til, maybe slightly lower sometimes. Pete
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:22pm
We hire a guy with a 8000 series white 16 row no-till planter, and it does a great job.
We mudded the first 50 acres in and it doesnt look fantastic, but no matter the brand of planter you will regret mudding in corn.
The wheat got hailed out, and he pulled right into still green standing wheat and planted corn, the chemical outfit came and hit the wheat with roundup the next day after planting to finish it and whatever growing weeds off. The stand looks awesome, and I am pretty happy with how things are looking on that field. Time will tell in the next 2 weeks, as we are not scheduled to get much if any rain.
IMO planting and spraying are not that fun, and there are alot of guys with big equipment happy to do a little custom work. IMO I would focus on harvest, that is where the fun is at.
IMO either get a nice 12 row 6000 or 8000 series white or case IH 800 series or newer (preferably 1200 series and newer) and DIY, or hire it out. The white meter is awesome, and the row unit is very good, and the CIH meter is good and the row unit is awesome.
Essentially the two best planters on the market in stock form are Red, especially for no-till. only the extremely Deere loyal run green planters out here, lots of CIH planters sold in our immediate area, many to farms that are otherwise green. Saw a 8370R pulling a 24 row central fill CIH planter just a few weeks ago putting in sunflowers.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 5:34am
Here everyone runs Deere planters regardless of the tractor pulling it. Seems like lots of 1760 planters have showed in the last few years. Only guys that run red are a couple die hard CIH guys the last White disappeared two years ago. A few Monosem's for veggies around. Buddy had a 800 that he had to fill the insecticide boxes with lime to get enough weight in it to no till with they are that much lighter than Deere.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 5:55am
I'll second the white planter. Very accurate and seed size doesn't affect them. I run a 6-30 6100 and wouldn't trade it for anything. There are a lot of kinze and Deere around here but still quite a few whites.
1terrygladys View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1terrygladys Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 8:20am
Almost every acre of corn planted around SW Iowa is no-till.  I planted no till for many years before retiring from farming in 2004 for the ministry.  It not only works, but it also gives the best yields in our area.  As I started using no till, I noticed the organic matter in my soil increasing with every soil test.  And with no till in dry years, you can always put the seed in moisture (not so if you've tilled it).  In addition, no till helps control soil erosion.
As they used to say in the TV commercial: try it, you'll like it!
Terry
WD-45, WD, Unstyled WC, SC Disk, JD 4430D, JD 4010D, JD B, Iowa pastor & disciple of Jesus Christ
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 9:15am
The so called wide wavy front coulter for no till is a bad idea. If the soil is a bit damp and with clay it can turn into a stomping packing wheel filled with soil and not benefit the soil or the planting process at all. The flat coulter I used made a good slot for 32% when planting corn and cut the stover whether planting corn or beans so the Trash Whippers were good and moving stover away from the opener disks and the combination prevented hairpinning of the stover by the opening disks. A combination suggested by Jim at Dawn at more than one farm show.
Gerald J.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 9:27am
My Deere 8 row I got 3 years ago came with a set of spring tines in front of the opener.  Made a great trash rakeAngry  What the heck conditions would that be for?  About the only thing I can think of is some sort of crust it would break up some...
My old 4 row had the wavy coulters.  We used it for over 20 years.  I had no idea it was so bad!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 3:26pm
The first owner of my 7000 (then 4 row wide) added a row of spring tooth harrow on the front of the frame. The up thrust lifted the planter enough the drive tire slid so the dealer added a drive chain to the other side. The tires still tended to slip and to plant irregularly and thinner than set. When I bought (from the second owner) at a consignment auction the spring tooth assembly was with it but not mounted. I left it and it got sold the next consignment auction for a few bucks. I converted it to 30" rows, added the Trash Whippers and the flat coulters and it planted no till fine for me. I took off one of the drive chains to save work on moving the drive wheels.
Gerald J.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 8:31pm
Makes a big difference what your soil is, we have 2 large farmers here who have no-til for 40 years, must work as they still do it.
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 9:06pm
Nobody tills in my part of the country. Corn, soybeans or cotton!!!
Edited by Eddie - 07 Jul 2017 at 9:07pm
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
charlesbendal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlesbendal Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 6:53am
We have been trying some no till for 3 years now so far we like it and it has been some of our top yielding corn and beans every year. We are using a corn bean rotation on everything we no till. I'm in North West Pennsylvania. The first year we planted corn no till we only had half a stand which was the planters fault it still way out yielded our corn across the road which was also ours planted the next day with a perfect stand
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 7:00am
Gerald J.
Interesting!
My 4 row 7000 had drive mechanisms on both tires....I thought that was standard.  It is set up so that it ratchets if one tire is moving faster than the other, like going around a sweeping curve or whatever, so that the out rows get a good population.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 9:43am
One drive chain has worked well on my 4 row narrow 7000. I found it was a bad idea planting on a curve like in a field corner. The row units move sideways until the trash whippers cut into the aluminum chain guard that I added to the drive wheel chain so the corn stalks didn't knock the chain off the sprockets. Much better to drive as far into the corner as possible, then lift the planter, back up, turn the tractor and planter and back into the corner, drop the planter and leave the corner driving straight. Then the combine going the opposite direction can drive straight into the corn (to the fence) then probably back up and move over a combine width and cut the outer rows cross the rows, then back up and turn to run down the rows normally, no harvesting going around the curve.
The two ratchet drives do take care of the two wheels turning different speeds on straight (different inflation) or corners whether planting or not.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 10:11am
That's a valid point about field corners.  4 rows I usually turned the corner, 8 rows I do not.  Guy just has to make a judgment call there.  But I have lots of fields with a "curvy" end that you'd not practically plant in a straight line.
This page was generated in 0.107 seconds.
