6080 engine RPM steady but gauge bouncing |
AC6080MAINE
Topic: 6080 engine RPM steady but gauge bouncingPosted: 04 Jul 2017 at 10:21am |
Tractor is running great but the gauge is acting up. It will bounce about 700 rpm. If I have the gauge bouncing from 500 rpm up to 1200, it sounds like it is at 1200, not in between. It's bouncing pretty hard, 4-5 times per second. Is this a an rpm gear or cable slipping?
We rescued the tractor from a retired farm where the owner passed away, and haying this week is probably the first time the tractor had a good load on in 10 years. Thanks for the help and happy 4th of July, all. |
Orange4ever
Joined: 01 Sep 2014 Location: Farmington, MO Points: 390 |
Posted: 04 Jul 2017 at 11:19am |
RPM gauge is electronic you probably have a loose wire on the alternator . ground is also possible alternator to be going out but lots of times it's just the wire going into the alternator into the side there's three of them together
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 04 Jul 2017 at 6:27pm |
Loose belt will make the tack jump
AC6080MAINE
Posted: 04 Jul 2017 at 10:20pm |
Thanks guys I will check both out. When I find the answer I'll report back!
WNYBill
Posted: 05 Jul 2017 at 8:46am |
Please tell us what you find....... my 6060 does the same thing. Bounces, sometime goes to zero and than will operate properly. Mine acts like a loose wire. Afraid to tear into the insterment panel........ and the Service Manual doesn't have much information. Mine has room for 2 fan belts but only has one, it seems to be tight. I'll check the alternator wires.
Bill
DougG
Posted: 05 Jul 2017 at 9:35am |
The 3 prong hookup on the Alt. is usually the place for a bad connection, take the side panel off on the right side up by the dash, that will get you access to the tach,ive worked on a few of these , sometimes you get lucky with a wire ,loose belt, but they are 30+ years old and anything electrical exposed to outside conditions do give out
AC6080MAINE
Posted: 08 Jun 2018 at 12:41pm |
Whoops, better late than never. The alternator ended up smoking out on me so I replaced it and it also solved the bouncing tach issue.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5316 |
Posted: 08 Jun 2018 at 9:46pm |
Dads 6060 would not go above 1,000 rpm this week. Checked the connector, cleaned, and then realized the alternator belt was so loose! Tightened it up and it resolved the issue. We had replaced both clutches and forgot to tighten the alternator back up. What a relief.
