180 3 point slow to go down
Aaron(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron(IN) Quote  Post ReplyReply Direct Link To This Post Topic: 180 3 point slow to go down
    Posted: 26 Jun 2017 at 11:22am
Had the 180 out this weekend and notice the 3pt would go up just fine, but would come down very slow with the lever.  After turning the tractor off the arms went down like normal.  Is it an issue with the pressure relieve valve or an o-ring in the control?  I checked the oil and it is OK.  Any help will be appreciated.
Thanks,
Aaron(IN)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 11:40am
If you are holding the lift/lower lever CLEAR FORWARD and is slow, I'd guess the Traction Booser plunger is being held in by linkage or plunger is binding.
