D12 Trans/Hyd Fluid
Jeeper38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeeper38 Quote  Post ReplyReply Direct Link To This Post Topic: D12 Trans/Hyd Fluid
    Posted: 14 Jun 2017 at 12:18pm
Just curious what people are using for the hydraulic/transmission fluid. This is in a 1963 D12 series II. Currently running "303" but I always think it seems like a very thin fluid. Maybe it should be. I'm running "303" because that what we used in them growing up.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 2:07pm
Original specification for the CA (and I think also for D-10/12) was 20W non-detergent motor oil, which is also pretty thin (but could take a while to warm up in the winter).
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 6:27pm
put in some lucas
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 6:33pm
I wouldn't go any thicker, considering the same oil is used in the hydraulic system. Hi Trans is your best bet. I wouldn't use additives of any sort.
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 10:00am
use lucas in final drives and transmissions wre 250 gear oil was what was to be used works great and is a additive for oil won't hurt a bit used it in thje 13 speed truck transmission it run 150 degree cooler this works
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 3:09pm
I agree
Rear Hydraulic Pump "SHARES OIL" with transmission and differential.
Running any kinda gear oil or thick additives increases chances of hydraulic behaviors .....
I would use OEM recommended oil......
Edited by Macon Rounds - 29 Jun 2017 at 3:16pm
