D 15 II oil filter
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: D 15 II oil filter
    Posted: 10 Jun 2017 at 8:56pm
I installed a Fram PH 8a oil filter on the tractor when finishing restoration.
It appears to me that the filter drains back into the crankcase after shut down.  Then it has to refill upon restart before the system is pressurized.
Is that the way they are supposed to be or is there an issue with the correct filter or some other leak down issue?
thanx
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 9:16am
That is the nature of the beast.  I have always used the PH8A on my D15.  No problems so far.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 9:30am
Some filters have better anti drainback valves than others. Switch to a Purolator and see if the problem goes away.
Edited by DougS - 11 Jun 2017 at 9:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 4:37pm
thanks guys, you put me at ease on that issue.
