D17 and Disk Mower or Cut/Ditioner?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: D17 and Disk Mower or Cut/Ditioner?
    Posted: 05 Jun 2017 at 8:23pm
Getting to my last nerve trying to cut a little hay with a sickle mower.  Has anyone had any luck running a smaller disk mower or a New Idea 7' Cut/Ditioner on a D17?  I have a front pump so hyd wouldn't be an issue.  I know not having the independent PTO would not be fun, but neither is what I am doing now.  When it works, it is a thing of beauty.  When it doesn't it could make the Pope cuss.
AaronSEIA
Edited by AaronSEIA - 05 Jun 2017 at 8:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 8:45pm
Look around for a drum mower, I pull a ccm 165 (5.5') with my D-12.  They are  heavy buggers, so don't go too much wider, or you'll need weights up front...
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 9:27pm
New Idea cut-ditioner will be good behind the D17. I pull a 9' one behind mine. I have been mowing hay with a D 17 since 1961, pulling a mounted, 3 point, or pull type sickle mower. I have not had a lot of trouble, gotta keep the sickle sharp and guards in good shape, need a grass board on the outer end of the bar and the grass rod on the inner shoe to keep things form plugging. Good luck with your mowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 9:28pm
Dad's D-15 pulls his 9' AC haybine just fine, but we use the 6060 ever since he bought it in 1981. D-17 shouldn't have any problem.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 5:51am
I have a New Idea 6' cutditioner in heavy hay it will make a D19 talk. Does a great job but does take some power.
Hyperpack View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hyperpack Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 8:18am
I run a 9 foot CutDitioner with a 190XT S3 and find in heavy clover it takes all the power the old Gal can make. I doubt a 17 would run a 7 foot in heavy hay.
Hyperpack
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 9:22am
I had a 9ft New Idea 299 Mowditioner and used my D17 but the 175 handled it way better. Really liked it but couldn't keep a gearbox in it.  Do not know if the cutditioner takes more power...Harvey
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 10:31am
A 7' or 9' diskbine will make you wonder why you didn't get one sooner.
Allis Express participant
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 10:55am
I agree 100%!
When I bought my discbine, our plans were to mow with both the discbine and our Hesston Hydra-Swing. After we bought the discbine, we rarely used the Hydra-Swing.
The discbine does take some power. I would think a D-17 would be a little small for a discbine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 11:42am
I used to run a half wore out dull bladed cutditioner with the 170 when I worked for a guy that did custom baling. Only ting I ever ran it in was cornstalks. we windrowed with it for the baler.
 I'm sure that 9 footer would pull harder in standing hay.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 11:43am
Your 17 will pull any 7 ft mower conditioner with crimper rolls. I had a cutdishner and you will use more fuel and time than you get from the hay your cutting. If it were me it would be a 7 ft disc mower that you have a dealer near. A mower conditioner will be slower. I'm using a 1320 hesston discbine behind a 6060 and in most hay it's ok. In rye or heavy hay I use a bigger tractor. Just my opinion and good luck, Scott
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 8:22pm
I have a NI Cutditioner and in regular hay it'll make the D19 work,that said its about my last choice of something to cut hay with.The only thing I ever found it to be really good for
was to scatter windrows that had been rained on.
