7030 Over full
summertime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote summertime Quote  Post ReplyReply Direct Link To This Post Topic: 7030 Over full
    Posted: 29 May 2017 at 5:09am
Transmission oil level is over full now. Rear end is low. Where is this transferring of oil happening?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 8:30am
A lot of places, but most common hydraulic pump and seal on pump drive shaft at pumps.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 8:32am
What does "now" mean ??  Like you've been doing something to the tractor and NOW it has this problem???   Tractor has to be on a very level surface and sitting for 15 minutes to get accurate readings. Trans dipstick has to be wiped clean and checked on both sides of the stick.  Until you correct oil levels, use the tractor and find it really has done it again, I'm not absolutely sure there is a problem. Oil transfer usually goes the other way on those tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote summertime Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 8:52am
First time to have it out this spring. Hook to 20 ft Batwing bushhog.Wouldn't raise lift cylinder after about 5 hours use. Checked oil at sight glass an couldn't see any. Let sit 2 hours an checked again​ that's when I noticed transmission was over full.Changed all oils an filters last fall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 2:33pm
Well, I'd think for the hydraulic oil to be low enough to affect the lifting, your power steering should have acted up and that would mean being maybe 10 gallons low on oil??? I don't think there's room for 10 gallons of oil to transfer into the tranny. I think you have an oil leak on the batwing and your tranny being overfull?? how much more on the dipstick?? an inch??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 9:45pm
Transmission dip stick is to the back, so if front of tractor is a little up hill, the dip stick will show over full. Front could have been down hill a little when filled so now shows over full.     MACK
