Front mounted hydraulic pump
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: Front mounted hydraulic pump
    Posted: 13 May 2017 at 3:35pm
I want to update my D19 diesel to an engine driven hydraulic pump. I thought somewhere I had read someone had a pump, mount and drive figured out aftermarket. Since the newest post I've found are 2012 and older I haven't had much luck.
If anybody has information or a used pump set up I'd appreciate it.
AGCO My Allis Gleaner Company
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 4:21pm
I think I read some place that a drive hub from a ford will work as well as the shaft and the pump.  but the hub had to be from a 600/800 series ford, because the bolt pattern is 4 3/4 on center.  If I'm wrong I'm sure somebody will correct me...lol
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 7:15pm
My D19 has a front pump that is factory as it was bought to use a loader on by the original owner.We bought it from him back in the late 60's.
