AGCO Allis 4650
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Topic: AGCO Allis 4650
    Posted: 11 May 2017 at 8:48am
Anybody familiar with these? Good or bad? Suppose parts are available? I understand they are air cooled? Thanks.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 2:27pm
4650 were very good units, independent PTO ,, we have had very few issues with the ones we have sold. Air cooled engines were  a plus... never been into one.. used the timing retard button on the fuel pump and they will crank a low temps w/o heat above 20 degrees.
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 3:00pm
We have found that what parts are not available from AGCO typically can still be bought from SAME if your SAME dealer is willing to look for them.  But as tbran says we had very few problems with the 46/5600 tractors.
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 3:06pm
Have a 5650. Bought used with 125 hrs. around 2000 only have about 350 hrs on it now, no problems other than rubber fuel lines deteriorating and leaking. Italian air-oil cooled made by SAME. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 4:16pm
yes, if any diesel has those cloth covered  (fire retard) hoses for fuel - that end in a banjo or slip on connections - replace it with fuel line or rubber chainsaw or weed eater line. .Simply cut the brass swedge off the banjo fitting , remove the rubber to reveal a barbed fitting - slip on fuel line and apply small hose clamp - for a long term fix.
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 5:49pm
Originally posted by tbran tbran wrote:
yes, if any diesel has those cloth coveredĀ  (fire retard) hoses for fuel - that end in a banjo or slip on connections - replace it with fuel line or rubber chainsaw or weed eater line. .Simply cut the brass swedge off the banjo fitting , remove the rubber to reveal a barbed fitting - slip on fuel line and apply small hose clamp - for a long term fix.
absolutely!! we made the mistake of ordering new fuel lines for a 5670 one time and not asking the price first cause we were in a hurry. I forget exactly how much they were but way out of line and over $100 for the set!! My dad was so mad he told them to send them back where they came from on a slow train and we did just what tbran said used 10-15 dollars worth of new fuel line and slipped it over the old barb. worked great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 6:15pm
Does anyone know the rated PTO HP? Tractordata.com says 50 engine and 40 PTO. One's I've seen for sale online the seller just simply says 50 HP. Thanks again.
