D-15 Series II will not run worth a....
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Topic: D-15 Series II will not run worth a....
    Posted: 05 May 2017 at 9:28pm
Y'all might see a classified post for a fire damaged D-15 series II. About had it.
Last summer my D15 got caught out in the rain. Somehow, it got water in the fuel. I drained the bowl and the carb. It ran OK but got to where it wouldn't idle really slow like it always did.
I tore down the carb and there was some rust and gunk in the bowl. Cleaned it up and it ran fair, but quit pretty much last fall. Had to limp to the barn with the choke on.
I ordered a platinum carb kit (every thing except a float) and dipped it and put it back together. Checked and double checked every port, all new jets, float is directly parallel ike instructions say (1/4 in).    Now itll idle great when cold, fair when warm. Wont run well at all (misses and backfires) above 1/3 to 3/4 throttle, dies above that.
It'll run a good pencil size steam of fuel out of the line and plenty from the bowl. The main jet seems best at about 1 round out. (this is missing and backfiring).
Should I be chasing down an electrical / firing issue? The cold / hot thing bothers me.
Anybody care to ohm out a new coil or known good coil for me?
How do you spin the motor so that the points are open widest for gapping? Manual says 0.022 but the kit comes with a 0.020 gauge.
Any advice appreciated.
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 9:55pm
You covered the carb and fuel bowl, but what about the fuel in the tank???  Could be bad gas and/or water in the gas.  Give the tank a good cleaning out at the same time.  Don't use gas from the barrel on the farm either - those things are notorious for letting water/condensation in. Try some fresh gas right from the station.
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 10:04pm
I put all new standard ignition parts in mine, their blue streak points and condenser, and their blue streak coil. Just keep bumping the starter til the points are widest on the cam on the distributor. I use a set of feeler guages and set at .022. Once changing points you need to check the timing with a light and at wide open throttle. Don't waste your time on junk points, napa echlin or standard blue streak. Don't give up, 15 II is one heck of a tractor.
Edited by cottonpatch - 05 May 2017 at 10:04pm
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 10:07pm
I had to keep opening my main jet up after rebuilding, I think it's at least 1.5 turns out. Idle jet is one turn out I think.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 8:43am
Valve lash
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 10:01am
Originally posted by JimD JimD wrote:
Valve lash
certainly needs checked
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 12:43pm
Valve lash didn't change overnight so shouldn't be the problem. Certainly won't hurt to check tho. Replace your points, condensor. Check coil - sounds like electrical problem. Check key and wires to key switch.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 8:29pm
Open the carb drain and see if fuel continuously flows freely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 8:49pm
Backfires are a sign of valve lash, timing, or both.I agree, didn't probly just start now. If you need the choke on, there is a fuel restriction somewhere. JMHO Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 9:02pm
to turn the engine to open points either
1) engage PTO and use pipewrench on PTO shaft to turn 'everything' til points are fully open... be sure to REMOVE pipewrench though....
or
2) use a small pry bar / big screwdriver and turn flywheel though the 'timing' hole. be carefull not to chip a tooth though...
running rough like you said... I'd get rid of 100% of the gas in the tank, sediment bowl ,steel line and carb. Start with FRESH gas....the 'gas' at the pumps with ethonal ATTRACTS water,it's heavy so sits at bottom of tank and is the first 'fuel' to get to the carb...
engine starts on idle ok ( note little case OK...) but under power demands..there's NOT enough gas in the gas/water mix to allow engine to run properly. I see it all the time on riders and snowblowers up here. Every one that I have to repair, I drain 100% of the fuel system, new filters,use carb cleaner, rinse tank with alcohol, etc. Maybe 'overkill' but I KNOW there won't be a 'fuel problem' after that.
Jay
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 9:11pm
Take a small glass and fill it from the drain hole in the carb,let it sit over night and see if you don't have water in the bottom of the glass.On all my gas tractors I've gone to putting a brass nipple in place of the drain plug then add a little gas line and a cheapie
lawn mower cut off to the end of the gas line.Turn it on drain a little gas out the bottom of the carb before I start up, also any small piece of rust or metal will fall in the line.
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 10:58pm
Saw a WD a while back  that had the same exact symptoms. Swapped carbs with another WD and it ran perfect! IIRC the main jet in the rebuild kit was too small. Hope this info helps.
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 8:56pm
Jay - it has fresh 100% gasoline. Did not consider the PTO. I'm gonna pull the plugs to put in autolite 295s so I'll do it then.
Doug / Tracy - it runs a stream about as big as a matchstick or a tad bigger out of the drain plug. Not as big a stream as the line itself will run, but seems like a pretty good stream for passing through the little hole in the needle/seat.
Lentsch - interesting. Gonna put the WD45 carb on it and try that.
Gary - good idea, I like it.
I cranked it up this afternoon and it ran PERFECT from idle to WOT... for maybe a minute. As soon as I could feelh
just a tad of heat off the radiator, the *issue* started.
I looked at the two bolts where the clamp pieces for the distributor are... there's enough old 'field paste' on them and the distributor stem to tell me it hasn't moved (been bumped / loosened) in a long time. Valve lash... gonna swap all the easy parts before I tear into that.
Appreciate the input, all!
C w/ 3rd gear out
WD 45 wide front
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 9:00pm
I'd be putting in a condenser.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 7:27am
check check your manifold for a vacuum leak, had the same issue on a ferguson, I was at my wits end till I discovered the leak now it runs perfect, I had the carb apart ten times cleaned it, checked the tank and nothing till I found that leak!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 8:04am
If you now have the carb to the point where the issue doesn't start until the engine gets warm I would be looking at ignition problems. Coils and condensers are notorious for causing those kind of issues when they get hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 4:41pm
Resolved.
New condenser fixed it right up.
Going to bench test the old one (which is practically brand new) and another new one - getting a spare for "just in case".
Thanks to everyone, especially Gary Burnett and cpg, for helping me get my mind right.
C w/ 3rd gear out
WD 45 wide front
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 6:25pm
Nope, it's a goner! Cry  You need to send it to Idaho, and I will give it a good "Retirement" home! LOL
Seriously, I can't add to what has already been said, just stick with it, she'll be just fine!
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 6:36pm
copyrite, I bushhogged about 4 acres this afternoon after I put the new condenser in. Problem solved.
C w/ 3rd gear out
WD 45 wide front
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 7:07pm
Really nice when these stories come to successful - and happy - outcomes! Thanks for sharing this one.....I'm betting it'll help someone else!
Dave
WC, CA, D14, WD45
