Adding auxilliary receptacle to 8030
Josh in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh in Pa Quote  Post ReplyReply Direct Link To This Post Topic: Adding auxilliary receptacle to 8030
    Posted: 05 May 2017 at 11:43am
I have an 8030 and would like to add an auxiliary receptacle to power flashers and tail lights on some newer implements. I understand this was a factory option, but mine doesn't have it. Where will I connect my harness? I assume in the dash. Will there be terminals on the flasher unit, and I assume light switch? Or will I have to splice into the existing wires? Thanks,
Josh
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 5:20pm
Should be some wires under the rear of the cab, kinda in front of the hydraulic valves,, dig around back there, you'll hafta put whatever plug ya want on
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 8:02pm
I just did my 8050. If you want some photos, list of materials etc., send me a PM with your email.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 9:48pm
Out behind the cab on the left hand side are two wire connectors. In them should be a left, right, tail, field light, and a ground. I am doing this from memory, so use a test light.
