AC7040 fuel line |
jazzsuds
Topic: AC7040 fuel linePosted: 27 Apr 2017 at 1:38pm |
I have an AC 7040 and I have fuel running from a 1/4" black tube under my deck on the fuel pump side when tractor is running. What is that tube, where does it go to and how do I fix it?
Edited by jazzsuds - 27 Apr 2017 at 1:39pm |
DrAllis
Posted: 27 Apr 2017 at 1:56pm |
Cut it in two where the bad spot is and splice it together with a piece of rubber hose and two hose clamps.
jazzsuds
Posted: 27 Apr 2017 at 2:09pm |
Thanks for the reply but it's leaking diesel fuel from the tube end. It looks like its a fuel release tube of some kind?
DrAllis
Posted: 27 Apr 2017 at 3:24pm |
I'm assuming it's fuel return to tank from the top of the injectors and the top of the injection pump. Cut an inch off of the bad end and reinstall.
jazzsuds
Posted: 27 Apr 2017 at 3:42pm |
OK thanks
jazzsuds
Posted: 19 May 2017 at 10:17am |
Hmmm I don't see where the fuel return line to the tank from the injectors attaches? Any ideas?
DrAllis
Posted: 19 May 2017 at 12:09pm |
Unless you've got some cobbled up plumbing, the fuel return line is at the #6 (rear) injector and goes under the cab to the top of the fuel tank.
jazzsuds
Posted: 19 May 2017 at 1:03pm |
OK thanks. I can't see the connection at the tank with the floor plate tight over top of the tank. Is it on the top side of the tank?
jazzsuds
Posted: 19 May 2017 at 1:04pm |
I guess I will have to remove the floor plate to get at the connection on the tank?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8757 |
Posted: 19 May 2017 at 1:11pm |
whatever it takes
MACK
Posted: 19 May 2017 at 9:28pm |
Loosen the two straps holding tank. Set a jack under tank and let it down a few inches. MACK
