190 Rams
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 190 Rams
    Posted: 26 Apr 2017 at 7:32am
The RAMS on my 190xt (I think they are the 3" ones) are leaking.
How hard is it to replace the seals/wiper/o-ring in these?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 8:27am
Take them off, unscrew outer nut, then pull shaft and packing out. Use cylinder hone to polish the best you can. Unscrew bottom nut and remove old packing. Loosen outer nut to replace oring. Lotite outer nut, screwing it against oring. Put new packing on lower nut, using Lottie on threads and stew nuts tight togather. Use a lot of grease on packing to put back into barrel. Tighten outer nut and put back on.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 10:18am
Thanks Mack!
Charlie
