What model is this disk?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: What model is this disk?
    Posted: 16 Apr 2017 at 8:51pm
A neighbor down the road has had this disk sitting along the side of the road for over a year, today I stopped to look and take pictures - didn't talk to him.  I've got some questions ... Can anyone tell me the model?  Looks to be 12' wide - I need something to go behind my dualled WD45.
Looks like it might have originally been a snap coupler, but the hitch looks pretty strong.
Is this the high pressure/low volume cylinder that is needed for the WD45?
Any idea what this piece does?  Looks like it's been broken for quite some time.
Blades all look good but don't know anything about the bearings.  What do you think it is worth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 8:59pm
Probably a 212 disc. It was a SC with traction booster hitch. The broken piece is a transport lock.That was a high pressure one way cylinder. They are good cutting disc. That one looks to have a few blades loose or broken, may a spool or two damaged.HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 9:06pm
Yea looking at pic the middle inside left gang has something going on with it
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 7:07am
Tracy has it right!
bearings are available for $300 each or you can rebuild them.
Could be aload for a 45 depending on how deep you can sink it in. I have a 10' and usually the wd45 with M$W's pulled it fine in 3rd. Once after plowing I used 2nd because it was pulling pretty hard.
You don't really need the lock unless you're using traction boost. THe idea was that when driving down the road you were always lifting up on the snap coupler, so you set the lock and let the hydraulics down. Mine was broke too and a good welder fixed it.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 7:30am
The blades could be dull, otherwise you'll be giving a '45 all it could do to pull that, especially in soft or plowed ground.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 7:59am
 Why does the transport lock break? I was told that when a two way cylinder is used that the down pressure would break the lock. All of the disc's I have seen with broken locks had two way cylinders on them so I assumed this was true. Now the disc pictured above has a broken lock but has a one way cylinder. What gives?
Thanks & God Bless
Dennis
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 8:23am
This is exactly how I broke one when I was a kid, had a two way cylinder on it, with the 190xt, and caught the lever turning in the seat on time, and "BANG" when I looked back, I saw the front half landing in the middle of the road behind me, just about the time the disk hit the gravel road.  OuchOuchOuch
Still in use:
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 8:27am
You could convert the hitch back to the snap coupler traction booster hitch. The WD-45 would have lots of traction then. I have the other part.
D17JIM2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM2 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 9:12am
Duals make big difference. Dad had a 13.5 Ft with snap couple and duals on fresh plowed ground in 2nd cornstalks in 3rd.
Edited by D17JIM2 - 17 Apr 2017 at 9:14am
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 6:48pm
the 45' will pull that good. W\ 4 tires will help a lot'
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 7:31pm
Looks like the leveling screw is rainbowed also
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 9:10pm
There is also this chisel plow at the same place.  Can anyone tell what kind it is?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 9:25pm
Dad bought a 13'6" disk similar to that but it had fold up wings on it. It was all the D17 wanted with duals on. That is a nice looking disk for its age.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 5:23am
Just a wild guess but could be a Graham plow.
