1949 Model D Motor Grader HELP!
TumblingIQ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TumblingIQ Quote  Post ReplyReply Direct Link To This Post Topic: 1949 Model D Motor Grader HELP!
    Posted: 05 Apr 2017 at 4:53pm
Just picked up a 1949 model D road grader and want to change the fluids. My question is I can find the drain plug at the bottom of the transmission and the fill level plug on the rear axle but the only fill plugs I can find are on the top of each of the tandem cases. Is there a transmission fill plug that i am missing or does the tandem cases, axle and transmission all share the same gear oil. Really appreciate all the help i can get. I don't want to drain anything without knowing how and how much to replace.
Edited by TumblingIQ - 05 Apr 2017 at 5:20pm
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 8:43pm
The units are all seprate an have their own fill/drain plugs. thanks; ac fleet
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 9:21pm
I don't have my grader any more or the service manuals but I seem to remember there was a plug on the side of the chain boxes that indicated the full level. You can get reproduction manuals from suppliers on this site.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 11:32pm
Tumbling, Welcome to the forum!  You might get more info if you go to the Construction Equipment link.
I have a D super and although I haven't changed the oil yet. I suspect the drain plug should be pretty obvious,  the fill/check plug should be on the side of the trans.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote TumblingIQ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 4:10pm
I finally found the little buggers all covered up in old dried oil. Glad I did, a bit of water came out in both cases. I think the chains now are happy campers.
Thanks for your response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 8:02am
Yes, !!
You can come here and practice anytime you want.  I've got a LONG driveway......
Post Options Post Options   Thanks (0) Thanks(0)   Quote TumblingIQ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 3:59pm
At a top speed of a sloth it might take me awhile to get there Wacko
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 5:31pm
The D grader we had would run bout 25 mph. But it would scare ya to run that fast. Lol.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:56pm
Yeah, in my opinion they were geared too fast. I think that is why they came out with the auxiliary step down transmission later on. The transaxle was made by Clark and may have been used for another purpose and adapted for the D graders and the Galion  503 grader.
