All Crop part ID?
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Topic: All Crop part ID?
    Posted: 31 Mar 2017 at 9:51pm
AC tag still attached is hard to read but I can make out the word CLIP.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 10:41pm
straw walkers
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 1:48am
They go on the straw rack. All-Crops don't have straw walkers, even though many people refer to them as such. They have a single rack that merely moves back and forth. Those things in your photo are called fishbacks and they are what go on the rack to move the straw. When the rack moves backwards, they slide under the straw (each fishback is composed of those triangle shaped "teeth". The longest part of the tooth (hypotenuse) faces the left side of the machine, and because it is a low angle it is easy for it to slide under the straw on the back stroke. On the forward stroke, the other edge of the tooth (almost a 90 degree vertical angle) collides with the straw, and propels it forward some. Then the process repeats.
I believe those you have fit a 90/100, due to each fishback having 8 "teeth".
Edited by CrestonM - 01 Apr 2017 at 1:55am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 4:20am
Dang Creston. Is there anything that you don't know about all crops! Lol! Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 11:36am
There's plenty left to learn! This time last year I knew a little about a 100 and nothing about a pull-type, but after bringing great-granddad's 60A back to life from its fencerow grave, I now know it like the back of my hand. Like was discussed in another thread, experience is key!
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 12:21pm
And anytime you work on them you learn something new! I have all five model of the pull type and love working on them!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 5:40pm
X2!
I have two 60A's, a super 100, and I'm working on a camel back and a 66. One day I'll have one of each model!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 6:49pm
Thanks guys! Grandpa only had 60's and 66's but maybe that explains why these were never used.
Anybody need these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 9:54am
There's a nice all crop 40 for sale Creston down there I think it's Brett Phillips, and there's several 90's around here!
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 7:06am
Are those thick (3/4" maybe) and wooded or like thin sheer metal? If they are thin, I'm thinking they go on the both edges of the straw rack and hold the center together. The center pieces that I think Creston is talking about on a 60/66/72 are thick and wooden. I have a rack out of a 60 and looked at it over the weekend... I used to have a 90 and I THINK the straw rack on it was all metal but I can't remember for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 9:26am
Yes, the ones on the 60's are thicker wooden pieces, and the teeth are not near as aggressive as these. I too believe the straw rack on the 90's are mostly (if not all) metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 10:29am
I have a 72 waiting to be worked on. Part of the metal straw rack is missing on the left side, just inside the door. I can't explain it well, but the metal "ribs or louvers" that go from front to back are gone for about 10 ribs. These ribs are the width of the straw rack.
The 72 came with a parts 66. I pulled the straw rack out of the 66 a couple years ago and it's sitting on the barn floor. The "ribs" are held in place by these saw tooth pieces that look just like the ones pictured. Then the saw tooth pieces are riveted or bolted to an external frame that holds the whole thing together. Like Creston said, the straw rack turns to wood as you get to the right side on a 60/66/72.
I'd have to dig out the parts book to tell for sure.
Edited by Allis dave - 03 Apr 2017 at 11:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 11:51am
Here's 1000 words. Found an old picture.
You can see where the rib slats or whatever they're called are missing.
On the left you can what look to me like the "clips" pictured above that hold the ribs in place.
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 11:03pm
Don't look like they belong on an All crop. I have a couple of those things. Will look at my parts book.
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 11:05pm
Allisdave the 72 is a 66 with an auger header.
This page was generated in 0.184 seconds.
