WD 3 bolt front axle bolster
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: WD 3 bolt front axle bolster
    Posted: 27 Feb 2017 at 3:28pm
Anybody have a template to burn a replacement bolster plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 7:43am
I'm just looking for a picture with dimensions
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 7:49am
Are you looking for the three bolt pivot? I have new ones made up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 8:18am
Lon,
I've got access to a laser at work and worked a trade with a local to build him a new pivot in exchange for a pair of fendors for my d15.  So I was just hoping to find a drawing with dimensions so I could laser him one quick.  Turns out he told me wrong, its a four bolt tractor he needs.  The pivot is completely egged out from loader use.  Worse case we may fill the hole and drill it back out.  If somebody has a detailed print or drawing they would be willing to share that would be awesome.  I'm not looking to mass produce as I can't do that but a one off part isn't a big deal to get done.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 11:00am
I have a 3 bolt not a 4. When I redid my front end a few years ago, I think there was kind of a smooth nut for the front pivot. I had it cut off and welded on a new one. then I drilled and tapped for a grease fitting. I'm having trouble not mixing up my memory with the front and back support, but I know I redid both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 11:37am
Do you guys know what diameter the bin is?  I measured at 1.25" but it wasn't perfectly round.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 6:23pm
The four bolt ones I have I removed the square piece on the back side, welded the hole and made a new square piece for the back. Then drilled in a new hole. The four bolt bracket has two tapered holes for mounting so it would be a bit harder to make up a new four bolt plate.
This page was generated in 0.252 seconds.
