WD final drive lube
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Topic: WD final drive lube
    Posted: 29 Jan 2017 at 9:04pm
I was looking in the manual for the final drive lube for my WD and it says SAE 140 above 32 degrees and SAE 90 below.  Looking online I get a lot of hits for 85W140.  Is this acceptable to cover the temp swings here in southern New England?  Any suggestions are appreciated.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 9:07pm
yes.
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 9:12pm
yes,mines had 80-90 in Illinois for 37 yrs
DougS View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 9:32pm
Just as engine oil has improved greatly, so has diff lube. In fact, lower viscosity lube will rob less power.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 11:22pm
Just going thru that now - you can see post below. I will refill with 80-90.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2017 at 2:47pm
In fact, when the B's came through in the 40's they came through with 140 in the transmission and final drive.  It was a pain getting it out when we put PTO and Hydrallic on.  Had to use Kerosene to clean out the old oil or else it would give the hydrallic a problem.
I believe all units sold in the 40's had 140 lub in the final drives.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2017 at 10:19pm
Hydraulic wet brake or universal hydraulic oil.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 8:07pm
Mack, universal hyd......oil or fluid?  What's the difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 7:22pm
Same, some call it one and another call it different. IH call it HI-tran, Ago call it 821, JD call it 303 or maybe some thing else today.    MACK
This page was generated in 0.062 seconds.
