1936 WC Timing
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Topic: 1936 WC Timing
    Posted: 22 Jan 2017 at 4:37pm
Hi, Guy's   On the 1936 WC With no starter Hand crank I was having trouble getting timed I had it Mag of and put #1 on TDC. For got about all the timing marks and Fire make is it on or on the bottom. Put #1 on TDC installed mag lined up rotor and put on cap and installed plugs. Drained out the gas the needle was stick taped carb got it all out and put in 91 octane and then carb was running gas out taped carb it stop. Chocked it once open chock cranked it for the second time it started up and I was surprised.
 One question on the timing I have the top of the mag turned all the way towards  the engine and the Fire mark in the top hole is just to the right of the center. I think it dose quite sound right to Me. It may be off some????
 Thank You
 Rod in MN
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 7:42pm
If it didn't kick you on your big a,----then the timing has got to be close!---having the mag all the way in,---sounds like off 1 tooth, check the mag teeth inside the cap,---could be off a tooth on that gear! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 2:53pm
 Hi. ac fleet.  I thought I may be off one but what way would I have to turn the rotor to get it right on. I don't want to turn it the wrong way and find it was I was wrong
Any help would be very helpful
Thank You
Rod in MN
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 9:16pm
The drive keyway on the back of the governor should be perfectly horizontal when number one is at TDC of the compression stroke.  Then the mag should end up being nearly straight up and down and the stud should be close to centered on the slot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 10:12pm
I need to look at my 36 out here in the yard and see if the mag is close to the block or in the center of the slots! thanks; ac fleet
